Author Topic: Error messages  (Read 1070 times)
SilverSurfer
  • Carrickfergus U.K.
  • Fancy a pint? This one's on me.
Error messages
« on: 09 February 2010, 20:40:34 »
Anyone have any idea why i'm getting an error "CHECK BRAKE LIGHT" when all the brake lights are working also "CHECK COOLANT LEVEL" when the coolant level is full :question :question
Welung666
Re: Error messages
« Reply #1 on: 09 February 2010, 20:48:06 »
CHECK BRAKE LIGHT = cheap bulbs, try and find a decent such as ring or genuine Vx.
CHECK COOLANT LEVEL = normally a faulty sensor in the tank, need a new one. About £30 all in from Vx
HTH :y
less
  • Hemel Hempstead
    • 2.6 auto saloon
Re: Error messages
« Reply #2 on: 09 February 2010, 20:50:19 »
Also, I think that there are 2 x brake lights each side - one on it's own and one combined stop/tail light. If one has failed you still get the warning message.
Re: Error messages
« Reply #3 on: 09 February 2010, 20:59:03 »
With the engine cold, remove the coolant tank cap and reach in with your fingers rotate the float 10 times and move it up and down 10 times....they can stick with poor coolant change intervals
SilverSurfer
Re: Error messages
« Reply #4 on: 09 February 2010, 21:02:10 »
I Will try this thanks guys ill let you know how i get on :y
« Last Edit: 09 February 2010, 21:02:34 by AMG »
Re: Error messages
« Reply #5 on: 09 February 2010, 22:23:30 »
Prefacelift have a stop/tail light & a separate tail light on EACH side. It appears that facelift just have a stop/tail light on each side ..... saloon cars!  :y
