Author Topic: Rough as a Badgers  (Read 1143 times)
davethediver
  • Blackburn, Lancs.
Rough as a Badgers
« on: 09 February 2010, 23:55:24 »
Hi guys just limped car home from shops, 50 mile drive back to home town from work car fine. Stop at shops and get in starts then cuts out, starts again EML on juddery to set of but then gets going albeit not picking feet up like normal.
Then as i get back to house sounds like something banging or ossibly running on three but not as bad when revved, sorry to be vague but any ideas? Could do with codes reading if anyone local has reader?
Cheers lads :y
P.A. Caron de Beaumarchais
goonv6
Re: Rough as a Badgers
« Reply #1 on: 10 February 2010, 00:08:37 »
Have you got the codes from it? Could be a number of things. I'm not au fait with the 2.2 but my first thought would be to check the DIS module. Sound like your not running a full complement.
davethediver
  • Blackburn, Lancs.
« Reply #2 on: 10 February 2010, 00:13:46 »
Not got codes yet hoping to get them read over next day or so :(
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #3 on: 10 February 2010, 05:05:43 »
sounds like a cam or crank sensor.
Welung666
« Reply #4 on: 10 February 2010, 05:52:57 »
Dave, pop the dispack out and check the plug wells for water/oil and check the dis boots for splits/cracking and white stains as a first easy step :y
