Author Topic: Oil gunge  (Read 1881 times)
SilverSurfer
  • Carrickfergus U.K.
  • Fancy a pint? This one's on me.
Oil gunge
« on: 09 February 2010, 21:42:17 »
Today i opened the engine oil filler cap and found it to be all sort of white gunge on the underside of the cap, also the top of the filler pipe was also coated in the creamy gunge. Is this normal as i thought this would suggest oil and water but i read somewhere on the forum last night about cleaning the creamy gunge off during an oil change :question
« Last Edit: 09 February 2010, 21:43:24 by AMG »
Re: Oil gunge
« Reply #1 on: 09 February 2010, 21:44:29 »
it should be nothing to worry about as long as there are no other issues, its referred to as 'mayo'.
its caused by short runs, not letting the engine get hot enough. Some oils also mayo much more than others, Castrol for instance is very bad for mayo. GM Semi Synth is a lot better.
I would do an oil change with some fresh GM oil, and take it on a long hard run  :y
Welung666
Re: Oil gunge
« Reply #2 on: 09 February 2010, 21:44:40 »
V6's get a lot of it in the winter especially when only doing short runs. Take the cap off and clean it, take the neck off and clean it, put the neck in the boot and fit the cap directly to the cam cover. I only used the neck when I had my V6 to top the oil up and it went straight back in the boot ;) :y
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: Oil gunge
« Reply #3 on: 09 February 2010, 21:45:41 »
Hi, I think this is quite normal on the Miggy especially if you do lowish miles.
Re: Oil gunge
« Reply #4 on: 09 February 2010, 21:46:04 »
Asuming youhave the V6 engine ... this is common.  The oil filler neck sits in a relatively "cold" part of the engine and so gets a fair bit of condensation inside it .. this emulsifies and causes the gunge.
It is worse with lots of short trips and ceratin oils.
A few decent length runs to get the whole engine really hot usually sorts it .. as well as changing to VX semi-synthetic 10W/40 oil . :)
SilverSurfer
Re: Oil gunge
« Reply #5 on: 09 February 2010, 21:48:45 »
Cheers guys you're really helpful and knowlegable this is by far the best forum i've ever been a menber of and i'm well pleased, chuffed ;D :y
Bumbazor
  • Worksop
Re: Oil gunge
« Reply #6 on: 09 February 2010, 22:06:53 »
You'll find that's a recurring feeling. There are loads of very helpful people here who have helped me by way of opinions, advice, parts, etc.
This is a very helpful and invaluable source of information.
Re: Oil gunge
« Reply #7 on: 09 February 2010, 22:07:35 »
Worth updating your profile with engine in your Omega, i noticed you had an Elite, which would be V6 or TD. Would help future diagnosis if you listed the engine  :y
SilverSurfer
Re: Oil gunge
« Reply #8 on: 09 February 2010, 22:18:54 »
Ok it's done :y
mudflap
  • NW London UK
  • My Green Goddess
Re: Oil gunge
« Reply #9 on: 10 February 2010, 06:59:34 »
I remember reading on a Frontera web site that the "mayonnaise" on the oil cap could indicate head gasket failure  - hope i'm wrong but it would be worth checking  :-?
« Last Edit: 10 February 2010, 07:01:46 by mudflap »
If it's got tits or wheels  it's bound to give you trouble
Re: Oil gunge
« Reply #10 on: 10 February 2010, 10:45:04 »
I can indicate it, but more often than not its the poor oil / short runs. HG would give other symptoms as well like coolant loss  :y
« Last Edit: 10 February 2010, 10:45:16 by tunnie »
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Re: Oil gunge
« Reply #11 on: 10 February 2010, 11:00:18 »
Hi, Had the same thing on an Astra, the thermostat had seized open resulting in engine not warming up!  :o
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
