Author Topic: Failed Mot emissions  (Read 3686 times)
TestTrak
  • Leicester
« on: 06 February 2010, 21:12:34 »
Hi all
The car failed MOT today on emmissions a little help needed
2.0 ltr 80.000 miles
runs great no problems at all,no eml light. no fault codes either
test result as follows
fast idle test    engine speed =2880 rpm pass
co                                       =0.57  %vol fail     0.30
hc                                       =131            pass   200
lambda                                = 1.022       pass  min 0.970 max 1.030
second fast idle
engine speed                       =3210   pass
co                                       =0.50   %vol fail    max 0.30
hc                                       =121        pass       200
any ideas what to look for
Thanks all
ians
  • Reading
Re: Failed Mot emissions
« Reply #1 on: 06 February 2010, 21:17:42 »
Probably worth doing a paperclip test anyway (in the guide section I think) - if you've not done that.
Beyond that a decent service (inc plugs and filter), fresh fuel and an italian tune up wouldn't go amiss ;)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 06 February 2010, 21:20:41 »
can you take the plugs out and see what colour they are mine failed like that a few years ago and it was the plugs gone. thet were bright red on the pole were the spark comes from.
« Last Edit: 06 February 2010, 21:21:33 by Russell_Hill »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 06 February 2010, 21:21:09 »
Best bit of advice i could give you mate is to clear out your breathers system  :y
waspy
« Reply #4 on: 06 February 2010, 21:21:44 »
When the tester's not looking pull his probe out (now now) & blow on it. Works every time ;)
Tried & tested :)
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 06 February 2010, 21:30:07 »
Tried & tested :)
 ;D ;D
Give your breathers a clean out mate :y this is also "Tried & Tested" :y
« Reply #6 on: 06 February 2010, 21:41:34 »
Clean the breathers then "drive it like you stole it" - sometimes called "an italian tuneup" - for a good few miles .....
Cleans the whole system out and gets the cats REALLY hot .... this cleans them and restores efficiency on many occasions.
Might help .. :)
TestTrak
  • Leicester
« Reply #7 on: 06 February 2010, 21:56:58 »
Thanks alot guys will get on it in the morning ive got ten days for a free re test,i think im going to change the plugs and clean out the breathers not done them for a while.
do i give it the (italian tune up) just before i take it back for re test ? :-[
Thanks again
Tim
« Reply #8 on: 06 February 2010, 22:02:29 »
I'd give it one a couple of days before hand ... and on the way to the test ... the tester "should" allow the engine to run until at operating temp before doing the test .. but this might not put max temp into the cats... so if you get them nice and hot on the way there, as you are only having a retest they should still be hot when it's done ... If the car is left standing obviously they'll cool down ... nowt you can do about that I suppose .. :(
amba
  • Medway towns
    • German V6
« Reply #9 on: 06 February 2010, 22:14:37 »
I had a similar failure on my annual MOT about 3 weeks ago.It failed on emissions and was advised that cat/lambda was at fault.
Added a fuel mixture from local factor to full tank of fuel and gave the car a really good blast down motorway with revs as high as possible.
Took car back to test centre for retest,and it passed with flying colours.When they asked had I replaced the parts...I told them no.....but only after I had the new test certificate.
hotel21
  • The Kingdom of Fife
« Reply #10 on: 06 February 2010, 22:18:40 »
Remember when giving your car a high revs tune up/clear out, you do not need to do mega leptons of speed.
The gearbox layout allows you to rev the nads of it in the low gears and not break the national speed limit....     ;)
waspy
« Reply #11 on: 06 February 2010, 22:21:25 »
Tried & tested :)
 ;D ;D
You may laugh, but it does work ;)
« Reply #12 on: 06 February 2010, 22:26:21 »
So Pete, just to clarify.If your car fail its MOT you pull the testers "probe" out and blow ?  :o :o ::) ;D ;D ;D...................personally I would rather buy a few new parts, but each to their own. ;) :D ;D
waspy
« Reply #13 on: 06 February 2010, 22:42:51 »
I knew it would end like this ;D
My mates Trans-Am failed badly on emissions. The tester blew on the probe, stuck it back in the exhaust & it passed with flying colours.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #14 on: 06 February 2010, 22:54:40 »
Must have had Camel Breath ;D
