Author Topic: two crank sensors which is for me?????  (Read 1932 times)
andy j cdx
  • liverpool  kirkby
« on: 10 February 2010, 17:46:31 »
hi everyone  ,hope someone can put me right .a friend of mine has two crank sensors. no1 part no 9148306n fits engines  y22xe....z22xe ...no2 part no 90540743n fits engines y26se....x30xe....y32se       dont no which i should have of him am i right in thinking my car ,a 2000 2.5 cdx  is engine no x25xe if so    then which crank sensor of the above  is the right one  for my car  any help clearing this up is  v welcome  thanks  :y
Re: two crank sensors which is for me?????
« Reply #1 on: 10 February 2010, 17:51:32 »
Neither !!!!
2.2/2.6/3.2 will NOT fit the 2.5 !!!  there are many crank sensors .. and you MUST have the right one
2.0 8v                                          90493864        £59.50        £53.56        £46.32
2.0 16v to 14194716                                      90458251       £59.50       £53.56       £46.32
2.0 16v from 14194717/31000001                                    9174621       £35.90       £32.36       £27.93
2.5 (early models)                                       90492006       £82.00       £73.80       £63.94
2.5 (later models)                                       90492061       £59.50       £53.56       £46.32
2.6/3.0/3.2                                        90540743       £53.50       £48.20       £41.47
2.0DTi/2.2DTi                                        90540188       £37.00       £33.30       £28.81
U25TD/X25TD                                        90487810       £85.50       £76.95       £66.79
You need to find out which of the 2.5 versions you have ...  the difference is in the electrical plug at the top end under the scuttle
« Last Edit: 10 February 2010, 17:53:00 by entwood »
ians
  • Reading
« Reply #2 on: 10 February 2010, 17:58:23 »
Does that imply the 3L ones are all the same then? ie 90540743
« Reply #3 on: 10 February 2010, 18:00:48 »
As far as I know ... yup .. :)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 10 February 2010, 21:05:43 »
theres two crank sensors for the V6.
   its simples  oval plug or square plug.
    early cars normally sq plug up to bout 1997 then its oval plug 1998 on.
Hoof'land storeman.
« Reply #5 on: 10 February 2010, 21:08:54 »
sort of correct ....
but only if you also add ... 2.5 V6
the sensor for the 2.6/3.0/3.2 V6 engines will NOT fit the 2.5 ...
biggriffin
« Reply #6 on: 10 February 2010, 21:31:00 »
the last engine swap i did was a  3.0l into a 2.5l the crank sensors were the same 1998 mini face lift oval plug.
Hoof'land storeman.
« Reply #7 on: 11 February 2010, 01:30:59 »
Yours will be 90492061 - thats an oval plug one and if you look underneath by the oil filter you should see black plastic end.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #8 on: 11 February 2010, 11:34:32 »
pulled a known good one of my old 2.5 and fitted it onto my 3.0 ( both oval plugs )   :y
