Author Topic: Broke Down!  (Read 3146 times)
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Broke Down!
« on: 09 February 2010, 14:20:00 »
Hi can someone give me some advise please. Tookthe car out this morning drove no problem. Stropped for about 10mins got back into the car drove off again no apparant problem, drove 500 yds came to some roadsworks stopped car dies tried to restart engine just turned over would no fire up tried for about 20mions then just as quickly as she died she started again drove home no chugging, no lack of response.
Is this the tale tale signs of a known problem!
Help appreciated!!
TIA
  :o
« Last Edit: 09 February 2010, 14:21:37 by cdgriffin »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Broke Down!
« Reply #1 on: 09 February 2010, 14:25:01 »
do a paperclip test and see if any codes are stored  :y
how too in the maintenence section  :y
Re: Broke Down!
« Reply #2 on: 09 February 2010, 14:37:35 »
You can't do a paper clip test, but you can do the pedal trick.
Bet you get a crank sensor code
« Last Edit: 09 February 2010, 15:07:50 by tunnie »
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: Broke Down!
« Reply #3 on: 09 February 2010, 14:39:35 »
Thanks Guys I'll do the pedal trick and post up the codes?
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: Broke Down!
« Reply #4 on: 09 February 2010, 14:43:42 »
Tunnie
Do you know the link to the pedal trick instructions - tried doing a search but can't seem to find?
Cheers mate
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: Broke Down!
« Reply #5 on: 09 February 2010, 14:52:38 »
Found it!!!!
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: Broke Down!
« Reply #6 on: 09 February 2010, 15:01:27 »
Ok pedal trick shows: 10 3 3 5
Can anyonetranslate please.
Re: Broke Down!
« Reply #7 on: 09 February 2010, 15:06:14 »
Codes here:
http://www.omegaowners.com/forum/YaBB.pl?num=1220619696
335 is the code (10 is start of sequence)
P0335 CrankshaftPosition sensor "A" circuit malfunction
Replace crank sensor, use geniune part  :y
« Last Edit: 09 February 2010, 15:06:45 by tunnie »
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: Broke Down!
« Reply #8 on: 09 February 2010, 15:11:22 »
Thanks Tunnie I'll get tehe car booked in to Vx asap!
Re: Broke Down!
« Reply #9 on: 09 February 2010, 15:14:59 »
 :-X :-X :-X
Personally, (if Entwood does not mind) i would drop him a PM, he is in your area. He has software to read codes, and belongs to ABS as gets cheap prices at Vx. Its an easy fix too!
Few beer vouchers his way, and you know the job has been done right!
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Re: Broke Down!
« Reply #10 on: 09 February 2010, 15:17:44 »
Yea he helped me with my first oil change a couple of weeks ago so he might no mind. No harm asking is there?
Re: Broke Down!
« Reply #11 on: 09 February 2010, 15:19:47 »
Nope  :y
Re: Broke Down!
« Reply #12 on: 09 February 2010, 20:33:44 »
More than happy to help .. PM's sent .. :)
and I "think" the 2.6 CS is the same as mine ...
SENSOR, CRANKSHAFT REVOLUTIONS Y26SE, X30XE, Y32SE        90540743
If so I have an unused spare we can compare with ...   :)
as for price .. I can't help :(  .. I bought one for the 2.5 and when I changed to the 3.2 I asked Skurrays if they could swap it .. and they did ... without any papwerwork !!!
Re: Broke Down!
« Reply #13 on: 09 February 2010, 20:46:19 »
Can you not get trade club with the ABS card?
And yes its the same part as the 3.2
Re: Broke Down!
« Reply #14 on: 09 February 2010, 20:53:58 »
Yup .. I have a TC ... and it saved Grif a small fortune on oil on his last vist...
on your hint .. checked Tc prices ..
2.6/3.0/3.2            90540743        £53.50        £48.20        £41.47
so a saving of £12 .. :)
