Author Topic: Sticky key  (Read 1536 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Sticky key
« on: 11 February 2010, 11:11:23 »
My ignition key is very tight to get out of ignition I was going to lubricate but thought I should get some advice first. Should I lubricate and if  so what should I use.
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Re: Sticky key
« Reply #1 on: 11 February 2010, 11:26:45 »
Hi
I lobbed some WD40 into mine and the door lock. Have done the same with our Astra for years, never had a problem.!  :y
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Welung666
Re: Sticky key
« Reply #2 on: 11 February 2010, 11:55:46 »
It's not just you Bixy and it's not a dig, but lots of others to that keep saying WD40 to lubricate things. WD40 is a water displacer, not a lubricant or penetrating fluid. It's useless for anything other than displacing water! Use a good quality lubricant on your ignition barrel. I use 3in1 PTFE spray to lube and PlusGas as a penetrating fluid.
Bixy1
    • Cats Tails
Re: Sticky key
« Reply #3 on: 11 February 2010, 14:03:51 »
Oh..........  :-/
Re: Sticky key
« Reply #4 on: 11 February 2010, 14:38:12 »
It's best to lubricate locks with something that won't go gungy and make matters worse IMHO. I would avoid most oils for this reason.
Scraping some graphite from a pencil onto the key and then inserting it might be worth a try.
PTFE lubricant might be worth a try?
Don't be tempted to mix different lubricants though!
Sir Popple
  • Roscommon, IRL (ex Cannock)
Re: Sticky key
« Reply #5 on: 11 February 2010, 14:46:08 »
I agree with all, WD40 is only fish oil and is only good as a water displacer or a cleaner, i should know i used to work with them. If ever you go the the States get Some PD Blaster this stuff is unreal.
