Author Topic: Help egr pipe broken!  (Read 1146 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 10 February 2010, 15:05:21 »
The metal pipe that links the exhuast manifold to the egr valve has snapped dealers want 65 for it!anyone on here got one?or can it be welded?
scream if you want to go faster!!!
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Help egr pipe broken!
« Reply #1 on: 10 February 2010, 15:08:46 »
brass welded will work most places only charge £10 and it dont rust. :y
« Reply #2 on: 10 February 2010, 15:13:50 »
Try one of the breakers in the parts section i'm sure you'll get on there :y
« Reply #3 on: 10 February 2010, 15:58:08 »
Probably have one kicking around you can have....not a common failure so should only be a few quid second hand.
mr ICE man
  • dolgellau wales
« Reply #4 on: 10 February 2010, 16:44:22 »
If you do have one I would really appreciate it!caled a few scrappies and they not got one just used some exhuast sealent for now seams to be ok but need to replace it!thanks all!your all amazing  ;D
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #5 on: 11 February 2010, 18:30:24 »
You can get away with blanking it, at least it means you are able to use the car until you get a replacement, if you decide to replace it...
« Reply #6 on: 11 February 2010, 18:32:22 »
/panto mode
Oh yes it is... ;)
May have one myself, if I haven't chucked it out (most of my TD bits I have binned now)
Page created in 0.029 seconds with 16 queries.
