Author Topic: Irmscher steering wheel and gear knob  (Read 3264 times)
robbo2345
  • Norfolk
  • the nature of the beast
    • 01/03 elite 2.6 estates
« on: 10 February 2010, 11:26:51 »
 :) Hi guys i want to remove my irmsher steering wheel and gear knob from my elite saloon  to my new elite estate has anyone any idea how to get gear knob off ? Also do i need to disconnect the battery or anything to remove airbag and steering wheel ? :-/ :-/ :y :y
life is too short ...... so live it every day !!
Hannah Judes Dad
    • the misses round the bend
Re: Irmscher steering wheel and gear knob
« Reply #1 on: 10 February 2010, 12:03:07 »
ALWAYS disconnect the battery when moving/replacing airbags then AFTER replacing airbag re-connect battery otherwise you will need a Tech 2 to reset your dahboard light.Also allow time for the airbag to de-activate before moving it(an hour is good).Hope that helps.
Welung666
« Reply #2 on: 10 February 2010, 12:09:34 »
AN hour is good but 5-10 minutes is plenty. Lift the leather gaitor on the gearstick there should be a grub screw to loosen to get the knob off ;)
Hannah Judes Dad
« Reply #3 on: 10 February 2010, 12:11:01 »
Ooeerr missus  ;D
« Last Edit: 10 February 2010, 12:12:18 by hannahjudesdad »
robbo2345
  • Norfolk
« Reply #4 on: 10 February 2010, 13:28:39 »
 :-/ :-[ :-/thanks guys i have taken the leather gater off but i cant see any grub screw ???? Any idea where it is located ?
« Reply #5 on: 10 February 2010, 13:35:48 »
Don`t think there is one. Gear knob IIRC is a pressure fit. Seem to recall someone a while back destroying the gearknob in an attempt to remove it :o
robbo2345
  • Norfolk
« Reply #6 on: 10 February 2010, 14:26:15 »
 :'( :'( :-/ :( :(does this meen i cant keep the irmscher gearknob or lever ???
mantahatch
« Reply #7 on: 10 February 2010, 14:29:06 »
Is it possible/feasible to change the whole lever over, rathe than just the nob ?
robbo2345
  • Norfolk
« Reply #8 on: 10 February 2010, 14:34:34 »
 :question :question i do hope so
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #9 on: 10 February 2010, 18:39:05 »
To remove the original nob you have to hack saw the plastic nob off but the irmscher is held on by a collarthat is held in place on the shaft by a small grub screw.
The irmscher is easy to remove by unscrewing the wood bit and then remove the collar.
Then you have the problem of what to put on there. Original is not an option. ::)
Jaguar XJ6
« Reply #10 on: 10 February 2010, 18:50:45 »
Is it possible/feasible to change the whole lever over, rathe than just the knob ?
I think that's what I would be looking at doing!
robbo2345
  • Norfolk
« Reply #11 on: 10 February 2010, 18:55:55 »
 :-/ :ythat seems the best option andy , perhaps daz will have an idea when he comes down lol
cmeonthemove
  • Taverham, Norwich
« Reply #12 on: 10 February 2010, 19:21:03 »
Is it your Elite he's coming down to look at on Friday?
Chris
2.5 Elite
robbo2345
  • Norfolk
« Reply #13 on: 10 February 2010, 21:02:00 »
yes it is its a 3.0 manual i have purchased a 99 2.5 elite estate again with a manual box more practical for me i guess he is coming to you first is he?  :y
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #14 on: 11 February 2010, 00:37:48 »
Hello,take it you've got the special puller to get the wheel off? :y
