Author Topic: LPG FILTER  (Read 1604 times)
sparten
  • ffoss-y-ffin,near aberaeron
  • usually,fixing his miggy
LPG FILTER
« on: 12 February 2010, 15:30:27 »
hi i think my filter is blocked as now i have car running ok on petrol and did run ok on lpg but now stalls when i put in neutral or park revs drop too much on petrol ok question is can i just undo the jubali on filter and swop with new one ,with engine off and cold of cause and is there any other filter in a lpg system
Re: LPG FILTER
« Reply #1 on: 12 February 2010, 16:13:33 »
turn engine off, and replace
also check evaporator is getting hot, and also check for any broken pipes etc
do you have the software for the LPG?
sparten
Re: LPG FILTER
« Reply #2 on: 12 February 2010, 16:47:14 »
software no chance total novice to lpg all pipes look appear to be good runs on lpg no prob just stalls come tickover seems like a restricksion hench filter ,nice to know that i can change filter no probs thought i would have gas hissing out if i undid filter that was all cheers james
Re: LPG FILTER
« Reply #3 on: 12 February 2010, 18:02:47 »
You will... Whilst the pressure drops :y :y :y
Just do it in a well ventilated area and be sure the ignition is off :y :y
