Author Topic: Wheel alignment - South Wales  (Read 3470 times)
mtbskills
  • Pontypool
« on: 10 February 2010, 09:39:19 »
Can anyone recommend a good place for this ? Near to pontypool if possible
WIM have been suggested, but too far for me !
Would like the full 4 wheel and camber check   :y
Thanks
Ddraigcymro
  • South Wales
  • Hate the game not the player!
Re: Wheel alignment - South Wales
« Reply #1 on: 10 February 2010, 11:47:19 »
Peter loyd raly in bryncethin(bridgend) they alwayse finished off my xr4i after all the after market stuff I put on them also get them to fine tune the cars just for reashurance, but hes local for me im not shure who closer again. Yes WiM have come highly recomended on here and also sethsmate sayse he will travle to WiM for his next alinement, he`s right in what he said to me it must be worth the travel as cost of trip will be less than a good set of rubber, it would be a full day trip for me to go to WiM so I am going to have to stick to local garages.
I don't suffer from insanity, I enjoy every minute of it.
mtbskills
  • Pontypool
« Reply #2 on: 10 February 2010, 12:47:40 »
Thanks for that, will ring them
Just talked to Kng David tyres in Risca, seem to know what they're talking about, £60 + vat
Seems reasonable !
Robin Hood
  • Nottingham
« Reply #3 on: 10 February 2010, 15:17:04 »
Almost spot on what I paid at Fleet Fit.  Results look good and since it took 1¾ hours (30mins freeing seriously seized rear wheel adjustment) I was happy to pay it.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 10 February 2010, 21:18:30 »
Peter Lloyd Rallying eh!
I was in school with this character, and the least said about my subsequent dealings with his operation, the better.
Seth
« Reply #5 on: 10 February 2010, 21:23:38 »
Turk has had his done somewhere up Llandeilo way in the past, but even he's subsequently made the trek to WIM.
That's why I'm gonna follow in his footsteps (tyre-treads) pretty soon.
mtbskills
  • Pontypool
« Reply #6 on: 11 February 2010, 11:09:46 »
Have they quoted for it at WIM ?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #7 on: 11 February 2010, 15:08:02 »
Take it from the members that have recommended WIM  and follow that advice, yes you will have a long trip but you will not end up having to pay twice for the car being set up, and you will know that THE MAN has worked the orical on your pride and joy. :y
Jaguar XJ6
mtbskills
  • Pontypool
« Reply #8 on: 11 February 2010, 16:09:30 »
Cheers for the advice, its not the distance but getting time off for the trip is the problem !
I'll get the other drop link changed and then get a price i think     :y
ffcgary1
  • Mitcham,Surrey.
« Reply #9 on: 11 February 2010, 17:18:17 »
Ok i understand the time is of premium for you, But you will end up having to pay for someone to look at your car and say to you " there you go all the settings are now to spec and in the green" you then shell out £60/70 notes and go on your way.
6 months later your tyres are rubbing out on the insde edge and you then have to replace the tyres and have the settings  checked and adjusted again, more expence and more time and hassel when you could have had it done once and done properly.Pls dont take this as a dig but more as food for thought. :y
Jaguar XJ6
« Reply #10 on: 11 February 2010, 17:26:43 »
Although its a long distance (Google says 135 miles each way) i would urge you make the trip.
Tony at WIM knows the Omega setup inside out, and they totally transform the handling, makes it feel like a new car. The machine they have there is excellent (Hawkeye i belive) not many of them in the country.
Last time i was there, an Aston Marton DB9 was on the ramps, local Aston garage sends all their cars there, shows how good they are  :y
It will be cheaper in the long run as they will get everything spot on  :)
« Last Edit: 11 February 2010, 17:30:04 by tunnie »
Martin_1962
« Reply #11 on: 11 February 2010, 18:45:18 »
What puzzles me is why is there an alignment place on the main road?
JasonH
« Reply #12 on: 11 February 2010, 20:55:42 »
Don't go to King David Tyres.
They sounded good and have all the kit but they didn't know what they were doing. They couldn't explain why one tyre was scrubbing (it was a worn wishbone bush) so I opted out of the expensive 4 wheel exercise and just got the tracking adjusted. I wasn't 100% certain they used the right settings for that either..........however that was irrelevant when I eventually figure out the problem.
« Last Edit: 11 February 2010, 20:56:08 by JasonH »
mtbskills
  • Pontypool
« Reply #13 on: 12 February 2010, 14:01:30 »
Thanks for the tips  :y
Gotta do something soon, changed the steering idler and both drop links, still feels like its got 2 flat tyres  (it hasn't  ;))
oh well, back under the car this weekend !
« Reply #14 on: 12 February 2010, 14:05:57 »
Ring WIM for recommendations - they are opening 100+ franchises very shortly, so they may already have a recommended place near you, using WIM knowledge and data
