Author Topic: interior heaters  (Read 1683 times)
mylowe5959
interior heaters
« on: 12 February 2010, 16:39:47 »
Hi,i have an omega c 2.2 estate with a interior heater fault,with both sides on HI it only blows hot air at the passenger side and cold air on the drivers side,can anyone shed any light on this,it doesn,t matter what the heat setting is as it still blows cold at the drivers side,any help would be greatly welcomed.Thanks.
Re: interior heaters
« Reply #1 on: 12 February 2010, 16:42:09 »
Blend valve actuator arm on the drivers side has popped off, see the maintenance guide section for how to fix
neilr
  • Barnet, Herts
« Reply #2 on: 12 February 2010, 16:42:12 »
iirc it probabley a linkage dropped off under the dash but im sure someone will give you a more detailed explanation was one on here alittle while ago
neilr
  • Barnet, Herts
« Reply #3 on: 12 February 2010, 16:48:57 »
sorry too slow
mylowe5959
« Reply #4 on: 12 February 2010, 17:10:27 »
Hi,just had a look in the guides and can,t see anything,is the blend valve on the side of the iar box or in the footwell.Thanks.
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #5 on: 13 February 2010, 08:25:06 »
there is a guide someware as it helped me i will go for a look and if i find it ill post on here but it is simple to do
Used  to have  two v6 and they roared
Now got 2.5 to Opel
