Author Topic: Vectra B V6 Plenums.............  (Read 3108 times)
Re: Vectra B V6 Plenums.............
« Reply #15 on: 14 February 2010, 22:30:05 »
It does but, its a more compromised setup to fit the smaller front wheel drive engine bay
Still compromised on VectraC? 3.2's of those are plentiful and cheap!
.....and will do the best part of 160 mph .....  :y
Trouble is the early ones are bl000dy ugly, the facelifted ones look loads better from the front.  But still not keen on those interiors. But for the money, can't complain  :-/
http://www.autotrader.co.uk/classified/advert/201005351859631/sort/priceasc/usedcars/engine-size-cars/3l_to_3-9l/model/vectra/make/vauxhall/radius/1501/page/1/postcode/sn48js?previous=%2Fsearch%2Fused%2Fcars%2Fvauxhall%2Fvectra%2Fpostcode%2Fsn48js%2Fradius%2F1501%2Fengine-size-cars%2F3l_to_3-9l%2Fsort%2Fpriceasc%2Fpage%2F1&logcode=p
Soooo cheap, low miles!  :o
But FWD then, and butt ugly  :(
That would do you :http://cgi.ebay.co.uk/2006-06-VAUXHALL-VECTRA-SPECIAL-VXR-ESTATE-V6-2-8T-FSH_W0QQitemZ140383306225QQcmdZViewItemQQptZAutomobiles_UK?hash=item20af7f41f1
Better engine 6 speed manual, trim pieces it needs are very easy to come by too.
Anyway on topic: Crank seal issues the veccy cam covers cause.
U
  • Latvia
« Reply #16 on: 15 February 2010, 04:13:41 »
may be a little offtopic - is there any description about Omegas multiRAM system? variable intake length system, which is used on Vectras is described in Vauxhall College pdf circulating internet.
« Reply #17 on: 15 February 2010, 08:45:14 »
Of course, its not hugely different.
What it compromises is the low down torque so wont affect high rev activity.
« Reply #18 on: 15 February 2010, 08:50:38 »
A bit like this:
http://www.omegaowners.com/forum/YaBB.pl?num=1153840176
« Reply #19 on: 15 February 2010, 08:55:37 »
Which, particularly in the case of 3.2 Vectra-C, due to its bloody awful chassis, is no bad thing, as it then stands some small chance of getting around the roundabouts of Milton Keynes without using the kerbs ::)
U
  • Latvia
« Reply #20 on: 15 February 2010, 11:06:40 »
