Author Topic: Removing throttle cable...  (Read 4176 times)
lou
  • Romford
  • Always expect the unexpected
« on: 15 February 2010, 16:21:10 »
I am about to take off the throttle body for a gas flowed one, but I am unsure how to remove the throttle cable from its ball socket, the cruise appears to be a E-clip. I am sure its easy but I dont want to damage any thing.
Re: Removing throttle cable...
« Reply #1 on: 15 February 2010, 16:27:56 »
thottle cable, small spring clip, just rotate spring clip, then withdraw. Then unclip the cable from the ball.
Cruise is simple E clip
lou
  • Romford
« Reply #2 on: 15 February 2010, 16:30:29 »
I have looked for that but can not see it, I wonder if anyone would have a pic of it..
« Reply #3 on: 15 February 2010, 16:30:51 »
You'll see a wire clip around the back of the ball/socket. Unlip it from the cable, rotate it 180o & it then slides out along the length of the cable - away from the ball/socket ........ not easy to explain. ::) Even when you have removed the clip, sometimes the socket can put up a fight in actually popping off the ball.
lou
  • Romford
« Reply #5 on: 15 February 2010, 16:36:45 »
Thanks for pic..Just as I suspected the clip is missing.Does that mean the metal back bit on ball socket slides along the cable?
« Reply #6 on: 15 February 2010, 16:36:53 »
Doh! I'll delete my photo's then!  ;) ;D ;D
Abiton
« Reply #7 on: 15 February 2010, 16:38:22 »
You're not kidding! I've tried and tried on ours and always failed.  (And yes, I had removed the clip  ;D)You don't want to break it, after all.
Is there a tool that could make this job easier, anyone?
« Reply #8 on: 15 February 2010, 16:39:19 »
If the clip is missing should just be able to prise the "ball" off. Might be a bit tight but it will release.
lou
  • Romford
« Reply #9 on: 15 February 2010, 16:40:34 »
Its obvious that some mechanic at some point did not put the clip back and there is me looking for it....lol
« Reply #10 on: 15 February 2010, 16:41:30 »
If you ever get your off, or look at A N Other, there's a wire clip that lives inside the socket. If it's never seen any lubrication in its life, then it rusts to the inside & won't flex as you try to get it off the ball. A little blob of grease works wonders for future removal.  :y  :y
« Reply #11 on: 15 February 2010, 16:42:28 »
Probably ended up in the engine bay at some time, they can be fiddly to put back.  :y
« Reply #12 on: 15 February 2010, 16:43:36 »
bloody crap design those things, another vote for DBW and its plug and play method  :D
« Reply #13 on: 15 February 2010, 16:46:44 »
They've been around a while. They're used as belts braces for a lot of gas struts ball & socket ends (our bonnets use another method  ::))
« Reply #14 on: 15 February 2010, 16:49:55 »
Its just so fiddly, and when it does go it usually goes pinging of at about 1,000 mph
« Last Edit: 15 February 2010, 16:50:10 by tunnie »
