Author Topic: TD no4 injector dilemma  (Read 1707 times)
unlucky alf
  • worksop, notts
« on: 16 February 2010, 12:18:48 »
o,k i received my replacement injector this morning, the problems ive got is: 1/ its got a black plug & mine is white. & 2/ the locating lug on the new one is in a different position, other than that the plug looks the same as the pins are marked up 1&2  the same as mine, is there a reason why the plug setup has been changed or can i just cut the locating lug off so it goes in. :-/
Welung666
Re: TD no4 injector dilemma
« Reply #1 on: 16 February 2010, 12:24:34 »
You should, if very careful with a pin, be able to remove the plug cover and swop it over to the original so it fits properly.
« Last Edit: 16 February 2010, 12:24:57 by Welung666 »
unlucky alf
  • worksop, notts
« Reply #2 on: 16 February 2010, 12:44:58 »
i did think of that welung but the wires are well sealed in the top of the plug, ive cut the lug off the plug now & marked the plug so i get it the correct way round, it still bugs me why the plug is slightly different, im just hoping its vx being awkward & not the fact that maybe the chip in the injector is set up differently, oh well id better go & try it, time to get my arm cut to bits getting it to plug in as its a swine to get to. :o :o :o
« Reply #3 on: 16 February 2010, 13:10:26 »
I guess you have the pre-maf diesel setup....
unlucky alf
  • worksop, notts
« Reply #4 on: 16 February 2010, 14:36:20 »
yup you got it mark,do you know if the plug is the only difference between the two?  it plugged in o,k after lobbing the lug off the plug & it starts & runs o,k,so please tell me other than the plug they are the same injector,,,,cheers :y :y
« Reply #5 on: 16 February 2010, 14:53:07 »
Well, given its only a piezo transducer you are probably ok...should work fine
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #6 on: 16 February 2010, 15:43:04 »
I had the same issue and trimmed the lug off. Been running it for about 2 years now, no problems.  :y
hoofing it
« Reply #7 on: 16 February 2010, 17:30:27 »
yip injector the same :y
