Author Topic: LPG FILTER LOCATION  (Read 918 times)
sparten
  • ffoss-y-ffin,near aberaeron
  • usually,fixing his miggy
LPG FILTER LOCATION
« on: 16 February 2010, 20:16:19 »
canister filter easy to replace but i have heard there are little round filter's in a unit some ware can some one tell me what i am to look for and ware a pic would be great and how easy or not is it to change/safty issue's ect  :)
Re: LPG FILTER LOCATION
« Reply #1 on: 16 February 2010, 21:07:58 »
It will either be integral to the Vaporiser or as a separate unit, very close to the vaporiser in the Liquid feed pipe from the tank... TBH, the liquid phase filter (if there's even one fitted ::)) has a normal service life of 80-100k, unless you are experiencing problems
sparten
« Reply #2 on: 16 February 2010, 21:27:03 »
sounds like that will be ok then i'll just change the canister then did take it off for a look ,looks brownie black allso knowen as knackerd,lol must be that as on gas it has developed a tendencie to hunt revs up and down on petrol ok must be blocked there on the move ok untill you put your foot down then it struggles abit and feels like it's missing a bit,hopefully it should cure it oh and cheers lazydocker
« Last Edit: 16 February 2010, 21:27:52 by sparten »
