Author Topic: cambelt  (Read 1841 times)
astroblaster
  • Chesterfield
    • 2.6 petrol auto cdx
cambelt
« on: 23 September 2009, 11:51:16 »
Hi i've read in some posts that when you change the cambelt you should change the water pump could someone tell me the reason for this, and should you change the water pump everytime you do the cambelt many thanx john :y
Do it today cause tomorrow it might be Illegal
mathewst
  • Split, Croatia
    • v40
Re: cambelt
« Reply #1 on: 23 September 2009, 11:58:37 »
The reason for this is if waterpump fails, the belt usually snaps (it happened to me).
You don't have to change it every time but I would suggest you do so ( or at least every second time).
If the waterpump is broken you need to change the belt also when changing the pump.
And it is cheaper to change the pump cause of belt than to change the belt cause of waterpump
Re: cambelt
« Reply #2 on: 23 September 2009, 12:02:58 »
Its recommended that the water pump be changed every 80,000 miles although I would replace mine at every cambelt change 40,000 miles as the water pumps are quite cheap and when doing the cambelt its only another 3 bolts to replace the water pump :y
astroblaster
  • Chesterfield
Re: cambelt
« Reply #3 on: 23 September 2009, 12:05:11 »
Thats great thanx very much for your help im definitly going to change the water pump when i do the cambelt :y
Re: cambelt
« Reply #4 on: 23 September 2009, 12:25:12 »
Changing water pumps when you change the cam belt is more applicable to 4 pot cars where the cam belt also drive the water pump. You have a 'fan belt' to drive your water pump on a V6  :y
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
Re: cambelt
« Reply #5 on: 18 February 2010, 10:53:32 »
So, at 80k miles do I need to or should I replace the pump when I change to cambelt on my 3.2 V6?
« Last Edit: 18 February 2010, 10:54:33 by merlindriver »
Re: cambelt
« Reply #6 on: 18 February 2010, 10:57:44 »
I would. A water pump isn't expensive and once you've got the car stripped for the cambelt its only an extra 3 bolts to do the water pump ;)
ians
  • Reading
Re: cambelt
« Reply #7 on: 18 February 2010, 11:00:57 »
If its not been changed already, at 80k you should generally change it.   Only costs 25 quid and if you later need to do it you'll have a couple of hours additional labour on top.
(In the case of 4 pots it is more critical though, as if the pump fails, it will likely take out the cambelt resulting in serious engine damage)
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
Re: cambelt
« Reply #8 on: 18 February 2010, 11:12:29 »
 :'( The local VH dealers have just quoted me £370- for the cambelt change and £507 for a cambelt and pump change (which they claimed was just the extra price of the part!)  I can't believe they'd want £137 for a water pump!!
Out of interest, how much is the tool to lock the cams, is it essential, and is there another way to do the job without the corect item?
« Last Edit: 18 February 2010, 11:16:18 by merlindriver »
Re: cambelt
« Reply #9 on: 18 February 2010, 11:16:06 »
 :'( The local VH dealers have just quoted me £370- for the cambelt change and 507 for a cambelt and pump change (which they claimed was just the price of the part!)  I can't beleive they'd wand £137 for a water pump!!
Anyway - Mr Elite Pete I have sent a PM.
The prices you were quoted are the non trade club prices. I think the prices are £126 for the cambelt kit and about £76 for the water pump and thats the genuine stuff, but you can get cheaper than that and good quality as well ;)
Re: cambelt
« Reply #10 on: 18 February 2010, 11:24:25 »
You can get the cam locking/timing tools off Ebay, prices vary but I got mine for £60 and I would go for a sealey one and not the Laser type and its a must to do the cambelt kit properly.
Varche
  • middle of Andalucia
    • Golf Estate
Re: cambelt
« Reply #11 on: 18 February 2010, 11:45:14 »
While you are at it, I would recommend getting an OOF cambelt change DVD. Well produced and easy to follow.
