Author Topic: 1 fix 3 new faults  (Read 3772 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: 1 fix 3 new faults
« Reply #15 on: 18 February 2010, 21:19:17 »
On a V6 petrol engine the first suspect for code 19 and random stalling/cutting out/non start would be the crank sensor.
I don't know if a diseasel needs a good crank sensor to run?
It's a crankshaft pulse pick-up on these.
Located by the starter motor, and picks up pulses from the flywheel.
hoofing it
« Reply #16 on: 18 February 2010, 21:28:36 »
nothing to do with power steering/fluid its a small filter located at the side of the res. with one pipe end going nowhere ill get a photo tomorrow and post it here.
as for it feeling like a lorry ive noticed it gets worse when it loaded have to keep lifting foot of gas then sink pedal to metal to overtake.
at least in a twenty year old lorry you can pull the limiter fuse and turn up fuel pump ;D ;D orions :othats going back now
Seth
« Reply #17 on: 18 February 2010, 21:30:38 »
See my post!
Does sound like the dreaded No.4 injector sarting to fail though.
Ddraigcymro
  • South Wales
  • Hate the game not the player!
« Reply #18 on: 18 February 2010, 21:34:37 »
[/quote]
That's the filter for the boost sensor.
One side's vented to the atmosphere, the other via rubber tubing to the EGR valve.
[/quote]
Are you referring to the filter just in front of where the pollen filter is ruffly,
I don't suffer from insanity, I enjoy every minute of it.
hoofing it
« Reply #19 on: 18 February 2010, 21:35:22 »
ah so thats where it is. I steam cleaned my engine last month its rather oily at starter hope ive not damaged it :o
Ddraigcymro
  • South Wales
« Reply #20 on: 18 February 2010, 21:38:37 »
doesn't the other end go to the egr and other to nothing this just a short end?
And is this the same filter you are on about sethsmate?
Seth
« Reply #21 on: 18 February 2010, 21:40:30 »
Yes, that's the one - it's got a glass dome on it.
Ddraigcymro
  • South Wales
« Reply #22 on: 18 February 2010, 21:58:38 »
So new battery and inj no 4 and that should sort out the problems with the car O and as all brake lights are working and the car comes to a stop in a safe distance the `37 Incorrect Brake Switch Signal` I can get away with ignoring just like the cruse control, as non fitted
Ddraigcymro
  • South Wales
« Reply #23 on: 18 February 2010, 22:20:32 »
Just out of curiosity can the inj no 4 be replaced with a non sensor inj and bye pass the ecu some how to not detect it, something like changing a efi to carbs , needed wold be, for easy way i found, was a distributor with points and run direct live to it. The cars run absolutely fine gearbox gave in in end first.
