Author Topic: strongest GM RWD gearbox(manual)  (Read 2470 times)
youngkadettkinin
« on: 16 February 2010, 21:13:48 »
i'm new here, just want to know what is the strongest manual gearbox GM make (i.e torque rating). The strongest i know of is the R28, which is rated for 280nm's(hence the 28 in r28). What  gearbox does the diesel omegas use?
Cheers
pedroMV6
  • York
  • Der Metzgermeister
Re: strongest GM RWD gearbox(manual)
« Reply #1 on: 16 February 2010, 21:17:08 »
Apart from looking Stateside at Corvettes, Camaros and trucks, a Getrag 265 as fitted to some Monzas?
Like rocking horse shit to find though! ::)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 16 February 2010, 21:26:22 »
diesel omega's use the r25 box for the manual
ar25 for the automatic  :y
« Reply #3 on: 16 February 2010, 21:28:58 »
Recomended to fit the AR35 if you chip the diesel.  AR35 fitted to the 3.2 V6 petrol auto as standard .. :)
No idea what manual box that has .. but it might be stronger ??
Welung666
« Reply #4 on: 16 February 2010, 21:31:23 »
Ex-cops use the R28 aswell even in 3.2 form.
youngkadettkinin
« Reply #5 on: 16 February 2010, 21:40:48 »
Thanks for all the help, anyone know does the monaro use the same gearbox bolt patern as GM's big block petrol engines(eg z22se, x20xev ect)? I know its a long shot :y
2woody
  • Northumberland
« Reply #6 on: 18 February 2010, 13:13:09 »
a couple of things here.......
All Omega A and Omega B manual gearboxes are Getrag 240, made in a GM-specific casing and with either shot-peened gears or not, according to the usage.
A Getrag 240 without shot-peened gears is called "R25"
A Getrag 240 with shot-peened gears is called "R28"
The bell-housing for these is integral with the gearbox casing and comes in three shapes - 4-cylinder petrol & diesel / V6, 6-cylinder diesel and "cam-in-head"
Other than that, there was a Getrag 265 used in some Senator A and Monzas, which uses a separate bellhousing. Beware, though, this bellhousing is "cam-in-head" bolt pattern and won't fit any Omega B engine.
There are three other strong GM boxes :-
ZF 6-speed. Used in Lotus Carlton - fits "cam-in-head" engines
Tremec T56 used in Commodore and Monaro - fits V8 only
Borg-Warner T5. Never used in any V-car
If you're contemplating more power, you don't automatically need a stronger gearbox. There is a natural limit for how much torque you can put through a 'box - and that's when the wheels spin. The "worst-case" for any gearbox is going to be re-starting a car with a heavy trailer on a hill.
hope this helps.
« Last Edit: 18 February 2010, 13:15:15 by 1417_stuart_grange »
2woody
  • Northumberland
« Reply #7 on: 19 February 2010, 08:53:09 »
thought of another option. You could fit a Ford "Type 9" box, using a specialist "conversion" bellhousing.
it's another option, but probably not much stronger than a "240".
unlucky mark mv6
  • tipton,west mids
« Reply #8 on: 19 February 2010, 09:38:25 »
If its a ford part,its probably about as much use as paper mache. :D
2woody
  • Northumberland
« Reply #9 on: 19 February 2010, 11:35:07 »
Aye, they're a bit "chocolate", but able to be rebuilt into something a lot stronger. The Caterham 6-speed version is actually quite a decent box.
all completely different to the Getrag units, for which there's nothing available.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #10 on: 19 February 2010, 20:11:15 »
arnt some of the boxes on beemers compatiable with gm fittings
Hoof'land storeman.
