Author Topic: Spark Plugs...  (Read 3005 times)
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Spark Plugs...
« on: 15 February 2010, 23:43:35 »
Evening all!
This is probably a really silly question but which is best, Vauxhall spark plugs or spurious, ie, NGK, Bosch etc, etc.
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Dave Elite
  • Ellesmere Port
Re: Spark Plugs...
« Reply #1 on: 16 February 2010, 00:23:19 »
I alway use Vauxhall ones.
I've tried and fitted the more expensive ones and had no improvement (not that you would expect any) and in some cases poorer running (i.e. Bosch Super 4's)
What you have to consider is that
 the Omega engines are pretty efficent so dont have massive cylinder temps unlike say a Turbo car
 and the engine management setup really extends the plug life through tight control of timing and mixture
If you check a set of 40K plugs and measure the elctrode gap, it will be pretty much the same as the day it was fitted!
« Last Edit: 16 February 2010, 00:24:04 by MV6Dave »
Re: Spark Plugs...
« Reply #2 on: 16 February 2010, 00:47:56 »
IMHO You can't sucessfully gap a set of OE plugs due to their design!   :-?  :-?  :-?
but I do agree with using Vauxhall plugs ... afterall they're only £15 a set  ;)  ;)  :y
« Last Edit: 16 February 2010, 00:51:28 by Andy_B »
Re: Spark Plugs...
« Reply #3 on: 16 February 2010, 02:56:17 »
cant beat vx for plugs and oil, esp on trade club, link below for the abs trade club card.
Bixy1
    • Cats Tails
Re: Spark Plugs...
« Reply #4 on: 16 February 2010, 10:29:57 »
Interesting!  Ok Vx it is then.  Thanks lads. A mechanic once told me plugs were important and as a general rule
Champions go in British Leyland, NGK's anything Japanese, Bosch anything German, and AC Delco in Vauxhall.
(This was a long while ago!)
As an aside, my GM engined diesel Astra had NGK heater plugs in and when I changed them for Vx ones starting was much improved!  :o
Re: Spark Plugs...
« Reply #5 on: 16 February 2010, 11:37:59 »
gm plugs made by bosch, same as you get in halfords for 1/3 the price or something like, just with the gm logo on.
Re: Spark Plugs...
« Reply #6 on: 16 February 2010, 11:44:36 »
As an aside, my GM engined diesel Astra had NGK heater plugs in and when I changed them for Vx ones starting was much improved:o
Probably because the old ones were goosed!
More often than not, the Vx OE glow plugs are Beru ones
Bixy1
    • Cats Tails
Re: Spark Plugs...
« Reply #7 on: 16 February 2010, 11:50:59 »
Yes you're right about them being Beru, but the old ones were new! Somebody had changed them just before I bought the car.  :o
Re: Spark Plugs...
« Reply #8 on: 16 February 2010, 12:23:39 »
I've tried Bosch and NGK.. all 4 electrode models..
and although NGKs are expensive I prefer them anyday.. and using them in both cars..
« Last Edit: 16 February 2010, 12:24:14 by cem_devecioglu »
Bixy1
    • Cats Tails
Re: Spark Plugs...
« Reply #9 on: 16 February 2010, 18:32:47 »
I'm impressed!  :o  Main Dealer parts cheaper than motor factors. 4 plugs, part no 9195109 GM branded, £14.92.  :y
Goody!
Not so good, bottom of rubber plug lead breaking off on 1 & 2. That was fun digging the bits out!  :(
New plug leads then.........
Re: Spark Plugs...
« Reply #10 on: 16 February 2010, 23:23:08 »
Goody!
Not such a nice price from the main dealer for these! Worth shopping around a bit. :y
Re: Spark Plugs...
« Reply #11 on: 17 February 2010, 00:14:28 »
Goody!
plug leads, 90 a side is it?
wishbones 230 a side?
springs 200 odd a pair depending on model iirc?
rediculous prices...
Bixy1
    • Cats Tails
Re: Spark Plugs...
« Reply #12 on: 19 February 2010, 19:28:29 »
No choice but to change the plug leads now, a slight misfire has started.  :( Can anybody recomend a good place to buy some?  Thanks all.  :-?
Richard A
  • Aldridge, West Midlands
Re: Spark Plugs...
« Reply #13 on: 19 February 2010, 20:23:36 »
Just fitted new leads, V6 Omega£24.98 delivered, great quality, lengths all a bit long, but not a problem, ebay.
regards
richard a
richard a
Bixy1
    • Cats Tails
Re: Spark Plugs...
« Reply #14 on: 19 February 2010, 20:58:24 »
Sounds good.  Price seem to vary from £104 to £14.99!  Whats going on there then??  :o
