Author Topic: please help  (Read 1854 times)
matt leadbetter
  • leicester
    • 01, 2.2 cdx estate
please help
« on: 16 February 2010, 19:15:03 »
hi i have a n reg 2.5 v6 and when I'm cruising at @ 60-70 @2.5-3k the car feels like its kangarooing i have changed the egr valve but its sill the same any idea's
Hannah Judes Dad
    • the misses round the bend
Re: please help
« Reply #1 on: 16 February 2010, 19:20:11 »
Check the maf sensor and then plugs/dis pack
Re: please help
« Reply #2 on: 16 February 2010, 19:20:36 »
does it run smooth at idle?
matt leadbetter
  • leicester
Re: please help
« Reply #3 on: 16 February 2010, 19:22:25 »
it does
Re: please help
« Reply #4 on: 16 February 2010, 19:25:12 »
Checked the plug well for oil ?
Re: please help
« Reply #5 on: 16 February 2010, 19:27:11 »
as above, take out the leads and check spark plugs for any oil or water, then do a paperclip test  :y
matt leadbetter
  • leicester
Re: please help
« Reply #6 on: 16 February 2010, 19:28:30 »
there is oil in at least one of the wells what paper clip test
Re: please help
« Reply #7 on: 16 February 2010, 19:31:04 »
details here on paper clip test:
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
You need to get that oil out, that could cause miss-fire at high rpm, also check cam cover gaskets are not leaking, that will case oil to get into the wells  :y
matt leadbetter
  • leicester
Re: please help
« Reply #8 on: 16 February 2010, 19:33:07 »
cheers buddy i will try that tomorrow
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: please help
« Reply #9 on: 16 February 2010, 21:44:50 »
if you have oil in there then the cam covers have gone  :(
clean your breathers out and you might have too replace the plug leads  >:(
update your profile too show where you are mate  :y
they maybe a member close to you who could help  :y
« Last Edit: 16 February 2010, 21:45:22 by tigers_gonads »
Welung666
Re: please help
« Reply #10 on: 16 February 2010, 21:48:20 »
I was just going to ask where you are :P
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: please help
« Reply #11 on: 16 February 2010, 22:09:21 »
too slow   :D :D ;D ;D ;D
Re: please help
« Reply #12 on: 17 February 2010, 08:43:42 »
MAF sensor (very unlikely given the conditions under which it occurs), DIS pack (spark related yes but, its now down 2 cylinders).....lets get the info we need before diving into possibles.
Anyway, the cause looks to have been pin pointed which is good.
As a hint to all.....the max spark voltage is requried when driving on a  constant throttle.....or accelerating from this condition.
matt leadbetter
  • leicester
Re: please help
« Reply #13 on: 20 February 2010, 13:36:44 »
I will update my profile now
Page created in 0.099 seconds with 16 queries.
