Author Topic: Lack of power  (Read 911 times)
Cuss
  • North Yorkshire
Lack of power
« on: 21 February 2010, 07:10:41 »
My omega seems to be lacking power around 2000rpm to 4000rpm.  It is very noticable because the acceleration is very sluggish then starts to pick up when revs get to around 4000rpm.
Not sure if it will be something mechanical or wherther a good service should sort the problem?.  Also thought about getting some of those additives you can get to add to the fuel which apparently cleans the injectors etc, anyone recommend a good brand?
Cuss
Cuss
53reg 2.6i V6 CDX
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Lack of power
« Reply #1 on: 21 February 2010, 09:40:59 »
redx is good, also can put in super unleaded say £10- and £5 normal95 unleaded, thak cleans them out to. and the exhaust. dont do all time. but would check plugs and plug leads first, and fuel filter.
« Last Edit: 21 February 2010, 09:43:13 by Russell_Hill »
Omega's is a life not just a car. also do ecu codes read and wiped or rest.., fix LCD tv & DVD recorders PS3's and most electrical equipment just e-mail me.
Re: Lack of power
« Reply #2 on: 21 February 2010, 10:22:12 »
check the multiram operation
GArlington
  • London, UK
Re: Lack of power
« Reply #3 on: 21 February 2010, 12:07:06 »
Cuss
Check that spark plugs are not flooded with oil - fairly common problem, if they are you will need to replace rocker cover gasket(s).
Re: Lack of power
« Reply #4 on: 21 February 2010, 15:19:49 »
That would be the one at back of plenum ?  :y
