Author Topic: clip fault codes  (Read 1763 times)
idc62
  • Llanharry south wales
    • x reg 2ltr gls and 03 2.6
clip fault codes
« on: 21 February 2010, 12:42:21 »
got a 2ltr 16v auto on 98/s reg are fault codes two digit or four digit and does clip test need ignition on only or engine running  cheers ian
Re: clip fault codes
« Reply #1 on: 21 February 2010, 13:48:56 »
idc62
« Reply #2 on: 21 February 2010, 16:24:43 »
did clip test with ignition on engine not running came back with 1 flash 5flash 10 flash 2 flash does 10 beome 0 if so 1502 what does that mean please if i got it right about the 10 flash that is  cheers ian
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #3 on: 21 February 2010, 16:40:57 »
If you only got 1502 it is immobiliser no signal,
not to sure but I believe its normal as the engion is not running, no doubt others will correct me if I'm wrong.
I have attached a fault code list for you to see the other codes.
http://www.omegaowners.com/forum/YaBB.pl?num=1206569945
He who brakes Looses
To old to die young
idc62
« Reply #4 on: 21 February 2010, 17:04:01 »
Thanks for reply ghost driver i was really pleaseed that was the only code to come up mind you i just did all the breather pipes,vacum pipes and cleaned throttle body and fuel pressure regulator replaced rocker gasket,replaced rad fan sensor,thermastat.Well now i can get on with wishbones,doughnuts, shocks,springs check steering idler and have a hand brake issue( it not very good) :y :y :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 21 February 2010, 17:10:13 »
blimey that sounds like a full rebild ;D
Hoof'land storeman.
idc62
« Reply #6 on: 21 February 2010, 17:20:19 »
Noooo just want it go well stop well and go around the bendy bits  proper     ;D ;D ;D :y :y
Ghost
    • 2.6 V6 CDX Estate
« Reply #7 on: 21 February 2010, 19:12:30 »
Keep us informed of your progress.
Good Luck with the work mate :y
To old to die young
idc62
« Reply #8 on: 21 February 2010, 21:07:27 »
will do :y :y :y
