Author Topic: Door check strap - fixing the A pillar mounting  (Read 1417 times)
Clouseau
  • Telford
  • Keeping the dream alive...
« on: 21 February 2010, 11:38:31 »
Well after a scintillating 14 hours I have replaced the head gasket and removed a bucket load of sludge/mayonnaise from the breathers, throttle body etc.  Runs like a new car with a perfect tickover.  :D
Nice.  Looks like a vindaloo and reminds me of that old joke about "sh*t in yer carb mate".....
Turning my attention to other things now. The driver's door check strap is a concern - there is no 'death crack' noise, and it has been kept well lubricated, but the bracket on the A pillar is starting to come loose.  The two spot welds nearest the car have given way and I have drilled these out and replaced with rivets. However this has only partially helped, and I suspect the steel behind the bracket is heavily corroded.
I seem to remember a thread on his which referred to a repair kit from Vauxhall (I think there was a plate which fitted from the other side, and a 'how to') but I can't find this anywhere.
Anyone point me in the right direction?
Thanks  Rich
hotel21
  • The Kingdom of Fife
Clouseau
  • Telford
Re: Door check strap - fixing the A pillar mounting
« Reply #2 on: 21 February 2010, 11:50:03 »
Ah.. thanks!  That was the thread I was looking for but unfortunately it doesn't solve my problem, which is at the other end of the 'strap'.  Anyone got any suggestions? I can make up a plate and bolt through to the otherside but what is the access going to be like?  Can I get to this from inside the wheel arch lining? :-/
hotel21
« Reply #3 on: 21 February 2010, 11:53:18 »
Have not had a look in that area but would think the internal A pillar access would be from inside the car cabin rather than from the wheel arch?  That is, removing the kick panel in the drivers footwell and possibly the assorted ECU's/wiring, temporarily, to get hand access.
If it was open via the wheelarch then all sorts of crudd would have ready access to inside the car cabin, I would have thought....   :-/
Welung666
« Reply #4 on: 21 February 2010, 12:20:20 »
Cruisetopoland's was coming away there to, I just ran a continuous weld around the edge of the inner section. Cured it straight off ;)
wingman
  • Hastings
    • Grandland GS
« Reply #5 on: 21 February 2010, 20:50:06 »
Yep, get it welded. Had my drivers side done about 2 years ago for free by the local Vx stealer (result!!!) and no probs since.
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #6 on: 21 February 2010, 21:55:27 »
[/highlight]
I didnt chek for the door strap mount but I just replaced a wing on my car and there is a bolt just next to the mount that you get to from behind the wheel arch liner from outside.
That said I would agree with welding it up instead.
Al
If it aint broken, you aint trying hard enough
