Author Topic: ecu change???  (Read 1883 times)
mowerman71
  • essex
  • go baby go
ecu change???
« on: 21 February 2010, 20:06:31 »
been offered a ECU from a 3litre v6 is it worth fitting to my 2.5 v6 and will it make any difference in performance , car running fine at the mo , but was wondering about changing it , any advice please , cheers , jon
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: ecu change???
« Reply #1 on: 21 February 2010, 20:23:34 »
cant change ecu on omega. as they are matched to the car and imobilizer. etc.
Hoof'land storeman.
Re: ecu change???
« Reply #2 on: 21 February 2010, 20:27:25 »
..and 2.5 and 3.0 ECUs have the same map in anyway, IIRC.
3.0 cams are a useful upgrade but the ECU won't make any difference.
biggriffin
Re: ecu change???
« Reply #3 on: 21 February 2010, 20:31:52 »
Cant beat cubes. put a 3.2 in it.
Hoof'land storeman.
Re: ecu change???
« Reply #4 on: 21 February 2010, 21:03:17 »
same ecu, not worth it
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: ecu change???
« Reply #5 on: 21 February 2010, 21:09:11 »
so, are the chips the same for the 2.5 & 3.0 then :-?
Re: ecu change???
« Reply #6 on: 21 February 2010, 21:20:50 »
I believe so.
The Red Baron
Re: ecu change???
« Reply #7 on: 21 February 2010, 21:25:43 »
I believe so.
ummm. thanks.
biggriffin
Re: ecu change???
« Reply #8 on: 21 February 2010, 22:28:51 »
the 3.0l chip has slightly more fuelling at the top end.
Hoof'land storeman.
mowerman71
  • essex
  • go baby go
Re: ecu change???
« Reply #9 on: 22 February 2010, 08:07:39 »
thanks all for the advice , think it will stay as it is , was just an idea , yep i like the idea of the cams being changed, cheers . jon
Re: ecu change???
« Reply #10 on: 22 February 2010, 08:42:37 »
Don't believe it does - the ECU 'learns' the fuelling required.
Re: ecu change???
« Reply #11 on: 22 February 2010, 10:29:21 »
The MAF sensor tells it how much air is entering the engine and it calculates required fuel from that. The map can therefore remain the same. It's just that a 2.5 won't be pulling as much air due to the smaller cylinder displacement.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: ecu change???
« Reply #12 on: 22 February 2010, 10:36:29 »
Took the words out of my mouth Mr Wood!
2woody
  • Northumberland
Re: ecu change???
« Reply #13 on: 22 February 2010, 11:33:38 »
I've just taken 3.0 cams out of my 2.6 and put the originals back in  - gained 4 HP
Re: ecu change???
« Reply #14 on: 22 February 2010, 11:43:09 »
You did something wrong then or have another issue.....when fitted to Mick Dundess, they gave around 17-18bhp with a buggered exhaust!
