Author Topic: plenum bolts size  (Read 851 times)
Bumbazor
  • Worksop
plenum bolts size
« on: 22 February 2010, 19:26:58 »
What is the thread size for the plenum bolts? I need to get a helicoil set to repair one of the holes in the inlet manifold.
serek
  • huntingdon
    • 3.2 mv6
Re: plenum bolts size
« Reply #1 on: 23 February 2010, 00:12:25 »
thread on plenum bolts is 8mm :y
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #2 on: 23 February 2010, 03:20:58 »
Yup, 8mm they are.
Were I you I would do the lot for good measure. You can even overtighten them with a 1/4" drive short ratchet! The problems are usually down to the correct torque not being applied after reassembly which is why a torque wrench is an absolute must on these jobs. For the sake of a one off cost it will save loads of heartache later.
GudLuk
« Last Edit: 23 February 2010, 03:21:22 by its.ray »
« Reply #3 on: 23 February 2010, 08:04:24 »
Yup, 8mm they are.
GudLuk
I wouln't helicoil them all, but I'm not really a fan of helicoils, there are other, better, thread inserts. Why do you need a torque wrench for 'these jobs'? Just tighten evenly & don't swing off your ratchet/spanner/etc, especially a steel bolt in ally, and you'll be fine.
