Author Topic: URGENT - locked out  (Read 1229 times)
ViaraiX
  • Rochester, Kent
URGENT - locked out
« on: 23 February 2010, 11:46:11 »
Been having probs with fuel pump as a result battery died from attempting to start.
Last night I took battery out to charge, locked car first (sure I only single locked it) then disconnected battery and shut bonnet.
Go out this morning and put key in drivers door, turn it - nothing!
Can get boot open and rear drivers side window is f**ked so could get to rear door lock, tried to pull it up and it is double locked :( is there anywhere in boot I could temporarily wire battery into so I can use fob?
Re: URGENT - locked out
« Reply #1 on: 23 February 2010, 11:53:04 »
...... is there anywhere in boot I could temporarily wire battery into so I can use fob?
The boot light.  :y  ;)
ViaraiX
  • Rochester, Kent
« Reply #2 on: 23 February 2010, 12:09:25 »
sorted :)
next question though... how do I stop the alarm going off everytime I reconnect battery now?
tried lock/unlock... doesnt do anything including locking or unlocking car
tried leaving key in and ignition turned on
ViaraiX
  • Rochester, Kent
« Reply #3 on: 23 February 2010, 12:10:33 »
oh and tried pulling horn fuse... dont work lol
(its the basic alarm using the horn)
« Reply #4 on: 23 February 2010, 12:17:59 »
sorted :)
Turning ignition on should stop the alarm.
Car horns live under the front nearside of the bumper, Alarm horn & siren live under the driver;'s side of the scuttle & are nowt to do with each other.  :y
ViaraiX
  • Rochester, Kent
« Reply #5 on: 23 February 2010, 12:38:02 »
sorted, cheers
