Author Topic: td code 37  (Read 1371 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
td code 37
« on: 24 February 2010, 09:13:42 »
would an incorrect brake switch signal be the reason my tractor just died on me 200 mtrs from home. its like a fuel issue again   :'(
hoofing it
Re: td code 37
« Reply #1 on: 24 February 2010, 11:21:57 »
when you say died did the engine stop running or did you loose power from the engine to gearbox
Ddraigcymro
  • South Wales
  • Hate the game not the player!
Re: td code 37
« Reply #2 on: 24 February 2010, 11:26:22 »
I am not as knowledgeable as others on here but I doubt it as mine ran ok and just ok, when i repaperclipt it, I have no doubt that a new / or just a battery giving more than 5v will allow my tractor to run ok again Even with the same fault code. Did other fault codes come up if so what. I also notice on mine that the fuel gage its not very accurate so wondering as you stated fuel problem have you much in the tank?
I don't suffer from insanity, I enjoy every minute of it.
Ddraigcymro
  • South Wales
Re: td code 37
« Reply #3 on: 24 February 2010, 11:37:05 »
Think we were 2 hours to late.
Sorry to see you now got your 81 hoofing it
raywilb
    • Citroen C4 Cactus
prime pump td
« Reply #4 on: 24 February 2010, 11:52:27 »
its the third time this has happened. i seem to drive about 300mtrs and it just dies on me. i cleaned lift pump & swirl pot out last time ( about 3 weeks ago) & its been ok since. is there a relay for the pump. the fuse is ok, but if i,m reading the fuse chart right the front seat adjustment are on the same fuse & the are not working. :-/
hoofing it
Re: td code 37
« Reply #5 on: 24 February 2010, 11:53:57 »
thats why i keep mine full(ish) same with my truck.
just had a mad brainwave have you checked the drain plug on the bottom of the fuel filter it could be slack and drawing air
Ddraigcymro
  • South Wales
Re: prime pump td
« Reply #6 on: 24 February 2010, 12:01:53 »
But were they working before, after the time the kift was cleaned
