Author Topic: Aux belt pulleys  (Read 1974 times)
mtbskills
  • Pontypool
Aux belt pulleys
« on: 24 February 2010, 11:47:09 »
in my quest to locate source of top end knock from engine (detailed in another thread )
noticed that top left (looking from front of car) aux belt pulley moving when revving engine.
Now i'm hoping thats the tensioner and its suppopsed to move  !!
Noise sounds a bit like a worn cam but only noticable when engine temp around 30 - 50 degress when warming up, ok when cold and normal running temp ...  :-?
megaomega123
Re: Aux belt pulleys
« Reply #1 on: 24 February 2010, 12:09:31 »
Have you slipped off the belt and run for a minute. Sounds similar to mine. The tensioner pulley does move slightly when load is applied. I am still trying to determine if the tensioner is likely to remain noisy after changing just the pulley.
mtbskills
  • Pontypool
« Reply #2 on: 24 February 2010, 12:53:44 »
I'll try it without the belt, good idea.
Is yours noisy on warm up too ?
megaomega123
« Reply #3 on: 24 February 2010, 13:18:25 »
Mine sounds a bit rattly on warm up and then just when you touch the throttle slightly. At least you can eliminate timing belt tensioner if you try it with aux belt off. Mine sounds lovely with aux belt off  :y
« Reply #4 on: 24 February 2010, 14:07:17 »
Pulley can be changed all on its own ... you do NOT need the whole assembly .. despite what some stealers will try and tell you.
Its a 10 minute / 1 spanner  job.
Part no 9157962   was £23 - 2 years ago...    :)
« Last Edit: 24 February 2010, 14:08:02 by entwood »
mtbskills
  • Pontypool
« Reply #5 on: 24 February 2010, 14:14:14 »
Cheers fellas  :y
Is it as simple as levering the pulley over and slipping the belt off ? Maybe after taking a photo to get the routing right, pretty serpentine down there  :o
« Reply #6 on: 24 February 2010, 14:22:44 »
Stick a ring spanner on the centre pulley bolt, take the tension off in a clockwise direction, lift off belt.
Rotate spanner in opposite direction to undo bolt.
When refitting the bolt you do it up against the tension .. then refit the belt.
Simples
HTH  :)
« Last Edit: 24 February 2010, 14:23:44 by entwood »
mtbskills
  • Pontypool
« Reply #7 on: 24 February 2010, 14:59:25 »
Thats ace ! Cheers Entwood   :y
ScaniaV8
  • Luton, Bedfordshire
« Reply #8 on: 24 February 2010, 15:07:32 »
For the uneducated and novice 'mechanic' :-)...can you please supply the abbreviations and their meaning please on the diagrams.... and explain the difference between the Blue and Red Serpentine versions.
Many thanks
« Reply #9 on: 24 February 2010, 15:24:10 »
Many thanks
T = Tensioner
GEN = Generator (alternator)
WP = Water pump
CS = Crank shaft
PAS = Power assisted steering pump
AC = Air conditiong compressor
G = guide?  :-/
blue or red ? depends if you have air con or not  :y
I believe that it's very early cars tha have the extra pully 'G', my 99 car doesn't have it.  ;)
ScaniaV8
« Reply #10 on: 24 February 2010, 15:32:01 »
For Andy B....thanks for the info...do you know what the 'G' pulley does as I have this on my early 1995 CDX 2.5 auto but the Aux belt fitted does not go over this 'G pulley' currently. Any ideas why not?
thanks
« Reply #11 on: 24 February 2010, 15:36:24 »
thanks
Sorry I don't  :-/. I would think yours isn't used cos when the 'fan belt' was last changed they either could get or just got the wrong belt for your car  ::). I wouldn't worry about not using it.  :y  :y
ScaniaV8
« Reply #12 on: 24 February 2010, 15:42:59 »
Darren (Darth Vader :-) fitted all new Cambelt kit and aux belt a few months back (1500 miles ago) so presumably I trust in the 'Dark side'   ;D
Just forgot to ask him what this 'G' pulley does !
Thanks anyway..cheers
