Author Topic: engine oil  (Read 1860 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
engine oil
« on: 24 February 2010, 22:06:04 »
If I do an oil change with 10/40 is it ok to top up with 15/40 ( 5 litres in my garage)  or would it be better to put 15/40 in when I do the change and forget 10/40
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: engine oil
« Reply #1 on: 24 February 2010, 22:07:34 »
i'd stick too 10/40  :y
mathewst
  • Split, Croatia
    • v40
Re: engine oil
« Reply #2 on: 24 February 2010, 22:08:57 »
Only top it up in an emergency. in athor cases avoid doing it
Re: engine oil
« Reply #3 on: 24 February 2010, 22:25:51 »
Stick with the 10/40.
Re: engine oil
« Reply #4 on: 24 February 2010, 23:37:42 »
believe they can mix ok, but personally i would keep to 10/40
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: engine oil
« Reply #5 on: 25 February 2010, 01:01:59 »
can't see any good for your motor so I'd stick with the same oil :y
Re: engine oil
« Reply #6 on: 25 February 2010, 13:57:44 »
I would imagine that the 15/40 is probably a mineral oil so not of the same standard as a semi synth like GM 10w40.
It will be fine for topping-up a car filled with semi-stynth, IMHO. It won't get added in sufficient quantity to make much difference.
If you were to fill a modern car 100% with it, I would bear in mind that it will have a shorter lifetime than a modern oil so adjust your oil change interval accordingly. Probably also best suited to use in the summer when it won't get too cold, given its' relatively high "winter" viscosity.
I would probably use it for topping up, for the lawn mower, or for when I come across a neglected car that needs a few short oil changes to clean the crud out.
