Author Topic: Why 'limp mode' ?  (Read 2342 times)
Steveplumb
  • Radstock, Near Bath
Why 'limp mode' ?
« on: 24 February 2010, 14:13:59 »
Any ideas why my 2.2 petrol Omega  sometimes ( maybe 1 in 15) starts in limp mode with the associated low power. No light comes on and is always overcome by switching off and re-starting straight away . Thanks
Welung666
Re: Why 'limp mode' ?
« Reply #1 on: 24 February 2010, 14:26:21 »
You need to get the stored codes read off your car. Where are you Steve?
Steveplumb
« Reply #2 on: 24 February 2010, 14:30:59 »
thanks for the reply, I am about 10 miles south of Bath
Steveplumb
« Reply #3 on: 24 February 2010, 15:03:47 »
I have considered getting a reader , are cheap ones available on eBay for £23.98   satisfactory ? If not, what  is recommended in the ' cheap' range . Thanks
« Reply #4 on: 24 February 2010, 17:16:31 »
Define please
Steveplumb
« Reply #5 on: 24 February 2010, 17:29:25 »
I mean in the range of those advertised around £20  -  £30. Is there a problem with these ? do they give accurate readings ? false readings?  miss errors ? etc  What is gained  with more expensive readers say £100 + etc
« Reply #6 on: 24 February 2010, 17:35:12 »
There's a "discussion" of code readers here ...
http://www.omegaowners.com/forum/YaBB.pl?num=1236032406
which might help.
I bought an ELM327 based cheap one .. and found it a total pain to be honest. So I bought the maxscan which I find much better. It only does engine stuff .. but that is sufficient for my needs... I doubt I'd understand much else !!!
vic
  • Aldershot (Hampshire)
« Reply #7 on: 24 February 2010, 19:30:44 »
Hi Steve,
Can't argue with 'good' the advice to get your codes read. My facelift 2.2 ecotec auto estate suffered from the same problem for months till it couldn't be cured by switching off and restarted. Anecdotal advice was to fit a new GM camshaft sensor, ...but do get the codes read first.
I did just that with some great advice from Kevin Wood and His Tech 2 :) :y and then fitted a new 'GM' cam sensor (sourced via Andyc) , and as if by magic ...problem solved and no more limp home problems on start up. Its a definite DIY job if you're at all 'handy and took me an hour and a half to do the job and cost about £60'ish.
Have written a 'How to' and hope it will be on the forum in a short while.
« Reply #8 on: 24 February 2010, 20:56:56 »
I suspect the faults you're seeing, you want a reader that can do engine and gearbox.  Legal versions of these will be beyond the budget you suggest (like 10 times over :o) :(
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #9 on: 25 February 2010, 07:57:30 »
Sounds like cam sensor problem (common symptom on a 2.2), but you need to get the codes read to confirm.
I like red cars
PC Techy
  • Bath
« Reply #10 on: 25 February 2010, 11:04:25 »
you have pm
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
Steveplumb
« Reply #11 on: 25 February 2010, 11:12:25 »
Thanks PC Techy............... please explain ?
« Reply #12 on: 25 February 2010, 14:00:50 »
Top left of the home screen you will see ....
Good afternoon Steveplumb
and  you have ?? messages and 1 new message
click on the new massage from PC Techy  :y  :y
