Author Topic: omega auto dim mirror wiring  (Read 1516 times)
omprezaman
« on: 24 February 2010, 21:43:56 »
hi new to the site can someone please give me the basic wiring to wire an elite auto dim mirror to a standard gls the place each wire goes to (ie heater,central lock,live etc)  AND whether Switched live/Constant live/or negative the wires from the mirror to the plug are:
BLACK /BROWN
GREY / YELLOW
BLUE / GREY
BLACK
PINK / PURPLE
PINK / GREEN
BROWN
GREY / BLACK
RED
/ BLACK
BLUE / WHITE
BLUE
RED
i am new to the forum so hope there are some experienced members able to help
« Last Edit: 24 February 2010, 21:46:11 by omprezaman »
Hannah Judes Dad
    • the misses round the bend
Re: omega auto dim mirror wiring
« Reply #1 on: 24 February 2010, 22:28:17 »
There was a guide put on here with some basics for doing the rear view dipping mirror,I hope this helps http://www.omegaowners.com/forum/YaBB.pl?num=1158088953  :y
« Reply #2 on: 24 February 2010, 23:05:09 »
Hannah Judes Dad
« Reply #3 on: 25 February 2010, 09:20:27 »
Thanks Rob,I don't know what happened with the copy and paste function but at least we are singing from the same song sheet!  :y
Bumbazor
  • Worksop
« Reply #4 on: 25 February 2010, 10:46:03 »
The URL is correct but it had a space at the end; it's the only difference I could find
omprezaman
« Reply #5 on: 25 February 2010, 15:43:28 »
thanks a lot for the help, regards
