Author Topic: vauxhall toyuta  (Read 1364 times)
dbr
  • north east.
    • 1997. 2.5CD petrol
vauxhall toyuta
« on: 24 February 2010, 23:45:55 »
1, thanks to Serek for indicator switch
2, Strange problem tonight that only lasted a couple of minutes. Foot off the accelerator but the revs on gear changes were going up from about 3500 rpm at the point I pushed the clutch  down to 4500 rpm. Normal after about 4mins / 2 miles. Something is going I suspect, but what? My first thought would be to strip / clean idle valve. Am I right? Any other thoughts?
Thanks in advance.
Dave
« Last Edit: 25 February 2010, 00:02:45 by dbr »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: vauxhall toyuta
« Reply #1 on: 25 February 2010, 10:37:26 »
give intake carb a clean had same problem with mine was a build up of muck in side, stopping it from closing proerly :y
dbr
  • north east.
Re: vauxhall toyuta
« Reply #2 on: 25 February 2010, 17:25:32 »
will give ago..this w/e
thanks
Re: vauxhall toyuta
« Reply #3 on: 25 February 2010, 17:46:13 »
There's a man living in the 80s ;D
Clean the ICV, throttle bodies and clear the breathers. Guides on this site.
dbr
  • north east.
Re: vauxhall toyuta
« Reply #4 on: 25 February 2010, 18:42:42 »
been there and done the 80's. n 70.s but a bit young in the 60's I understood the idea.
