Author Topic: Auto box interlock  (Read 2214 times)
ians
  • Reading
Auto box interlock
« on: 25 February 2010, 11:17:17 »
Seems to be playing up.  (I'm talking about the function that requires pressure on the brake pedal in order to shift out of Park)
There is usually a click from the selector when the brake pedal is pressed - presumably the locking solenoid firing.  This click doesn't always happen on mine.  When it does I can move the selector as normal.
So is this likely to be a switch at the brake pedal end (where is it?) or a problem with the solenoid (again - how do you access that?)
Cheers,
Ian
Varche
  • middle of Andalucia
    • Golf Estate
Re: Auto box interlock
« Reply #1 on: 25 February 2010, 11:39:32 »
Don't know the answer to where the solenoid is.
There is a manual switch to free the gear lever located under the gear lever gaiter for desperate times. My car won't start in neutral only in park. I just live with that.
« Reply #2 on: 25 February 2010, 11:42:04 »
So is this likely to be a switch at the brake pedal end (where is it?)  .......
You need a new brake switch. It lives above the brake pedal  :y
ians
  • Reading
« Reply #3 on: 25 February 2010, 11:47:31 »
is that a dealer part or scrappy job?
« Reply #4 on: 25 February 2010, 12:22:52 »
Either and if you`ve got cruise make sure it`s the 4-pin one
« Reply #5 on: 25 February 2010, 13:15:39 »
They're not expensive new, there's always the chance of buying a dud or near dud 2nd hand switch.
ians
  • Reading
« Reply #6 on: 25 February 2010, 14:24:55 »
Indeed.
Does anyone have a part no.?
This is a 98 Elite (so with cruise)
« Reply #7 on: 25 February 2010, 16:55:51 »
Could be brake switch (top of pedal), but also solenoid. To get to (and check) solenoid, put up on the leather in front of the gear lever.  You can see solenoid, it has a bright yellow lever for manually disengaging.
« Reply #8 on: 25 February 2010, 17:43:38 »
....but also solenoid. To get to (and check) solenoid, put up on the leather in front of the gear lever.  You can see solenoid, it has a bright yellow lever for manually disengaging.
Could be, more likely to be the brake switch though  ;)
« Last Edit: 25 February 2010, 17:44:09 by Andy_B »
« Reply #9 on: 25 February 2010, 17:44:21 »
Probably, but as I'd test before replacing parts, solenoif easier to get a meter on ;)
ians
  • Reading
« Reply #10 on: 26 February 2010, 10:57:20 »
Is the 'brake switch' the same device that switches the brake lights on?  So if that is the culprit, then the brake lights will not be on either?
But if the brake lights are on, then more likely the solenoid?
Are both parts straightforward access?
Cheers
Ian
« Reply #11 on: 26 February 2010, 11:02:08 »
Cheers
Ian
Solenoid easy to get at, Brake switch easy to get at with your head upside down in foot well. Bugger to remove though
« Reply #12 on: 26 February 2010, 11:11:02 »
Cheers
Ian
As I recall  .. the switch is a twin element affair .. so one side - interlock - can fail but the other side - brake lights - still work.
A multimeter check should enable you to confirm the switch .. :)
