Author Topic: Plenum O rings  (Read 2008 times)
manny
  • bromorough.Wirral.
Plenum O rings
« on: 25 February 2010, 19:23:25 »
Does anyone know the diameter of the O rings under the plenum? Got loads of O rings in work. Dont really want to take it apart to measure size .
2001 OMEGA MV6
manny
Re: Plenum O rings
« Reply #1 on: 25 February 2010, 21:05:08 »
Ok then does any one have a part number?
2001 OMEGA MV6
Re: Plenum O rings
« Reply #2 on: 25 February 2010, 21:38:11 »
9118135
Bumbazor
  • Worksop
Re: Plenum O rings
« Reply #3 on: 25 February 2010, 22:11:40 »
and I think they come in packs of 6, and cost a bit more than a tenner
Re: Plenum O rings
« Reply #4 on: 26 February 2010, 09:17:56 »
£10.76 +vat
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Plenum O rings
« Reply #5 on: 26 February 2010, 09:37:42 »
I have just purchased two items which were said to be needed fot the pleneum in an earlier post have I got the wrong ones  pack of 2 90467543 funny 3/4 inch plastic items pack of 5 90500983 tiny rubber o rings 3/8inch
Bumbazor
  • Worksop
Re: Plenum O rings
« Reply #6 on: 26 February 2010, 09:50:09 »
90467543 is the breather bridge to plenum seal
90500983 are the breather bridge to threottle body O rings.
Both are fairly cheap so you haven't wasted money really, and you might as well replace with new now you have them.
Re: Plenum O rings
« Reply #7 on: 26 February 2010, 10:33:28 »
Always handy to have the full set when doing breathers. That way if one fails as you take it apart....
If you don't use them, you have them ready for next year, when you do the breathers again :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Plenum O rings
« Reply #8 on: 26 February 2010, 11:02:12 »
Thanks The Boy Are these 2 items all I need to do the breathers?
Re: Plenum O rings
« Reply #9 on: 26 February 2010, 11:02:55 »
Not followed this thread that carefully - have a look in the maint guide :y
Damien (Danio)
  • Sklemersdale
Re: Plenum O rings
« Reply #10 on: 26 February 2010, 14:40:32 »
Gm part for that is 9118135
I've just bought mine for 12.24+VAT in VX dealer.
