Author Topic: LED replacement bulbs  (Read 3754 times)
ianu
  • Oxfordshire
    • XC90/Maserati QPV/CooperS
« on: 31 October 2009, 20:57:09 »
Hi all,
Has anyone here done the rounds with LED replacements for the following bulbs:
Front Sidelight x2, Indicators x4 + flasher can replacement, Reverse lights x2, Rear Fog x2.
Any recommendations on what's best for some or all would be much appreciated.
It'll be for a f/l 2.6 Elite saloon.
Thanks
Ian.
Re: LED replacement bulbs
« Reply #1 on: 31 October 2009, 20:58:54 »
Whats the motivation? I have had my facelift for almost 5 years, in that time only 1 bulb has blown!
sport
  • Stoke on Trent
« Reply #2 on: 31 October 2009, 21:27:18 »
Good for front side lights but not so good for any other outside  lights ok facing the bulb but you loose the brightness from the side
« Reply #3 on: 31 October 2009, 22:07:24 »
Hi all,
Thanks
Ian.
Not sure anyone has to be honest.
You'd need to ensure the check control is still happy, and not sure if you'd need to do anything about difusing the normally very direction LEDs in the rear lights...
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 31 October 2009, 22:16:50 »
Some of the LEDs in use in yacht are worth a look.  Good quality and not focused in one direction (unless you want them to be)
Check online chandlers :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #5 on: 31 October 2009, 23:02:02 »
I will admit to using "Snazzy blue effect" sidelights, my old ones looked yellow next to Xenons. Other than that all mine are original equipment. I am tempted by brake lights, I can see the advantage, faster warning of braking to the car behind has to be a good thing.
« Last Edit: 31 October 2009, 23:02:26 by Agemo »
« Reply #6 on: 31 October 2009, 23:19:25 »
Which wont pass the MOT.
My Elite has them in, only reason they are still there is I am too lazy to change them.  Was told by the MOT tester they normally dont pass them, but he let me off coz i told him I dont drive the car at night.   ::)
Pete Elite
  • Uxbridge, Middlesex
« Reply #7 on: 31 October 2009, 23:42:00 »
   I've got them on mine and the MOTer didn't even mention them :-?.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #8 on: 01 November 2009, 00:59:19 »
LED side lights give a brighter light, but they don't emit light towards the reflector. Changed mine back to standard.  Chavvy "boy racer" look.
« Reply #9 on: 01 November 2009, 01:53:13 »
They didnt on mine last year, but made a point of mentioning them this year.  Never said a word about the air freshner though.  ::)
KillerWatt
« Reply #10 on: 01 November 2009, 02:38:17 »
You are talking milliseconds, and while some human brains are quicker than others by milliseconds, the right leg ain't.
pedroMV6
  • York
  • Der Metzgermeister
« Reply #11 on: 01 November 2009, 09:46:41 »
I have allsorts od bulbs kicking about including some LED brake bulbs - tried one in the MV6 and the brakelight out warning came up.
Dunno if pre-face would have the same issue?
ianu
  • Oxfordshire
« Reply #12 on: 01 November 2009, 18:50:44 »
Thanks all - I agree you need to be careful about the directional capability - but I know some of the bulbs have a 'tower' design which gives a near 360 spread. I wondered if anyone had had any problems with the correct bayonet fitting ?
I know for the indicators (orange bulb) the pins are offset around the circumference and the flasher can would also need replacing. All the clear white bulbs seem to be standard opposite offset or straight bayonet.
The front sidelights do look weak next to the xenons - I'll try a pair of 9 led tower and let you know.
Cheers
Ian.
cruisetopoland
  • UK
« Reply #13 on: 01 November 2009, 19:05:21 »
Cheers
Ian.
I usually fit 12LED w5w sidelights to my cars-was due to get round to the Omega this weekend.  I am expecting a "bulb out" message issue though as they use less power than standard bulbs.  Will let you know-may not be an issue.
You can buy "no fault/error code" LED bulbs off ebay though  :y
If they are the right bulb for the app, they can look nice-but it is very easy to order wrong type which do not shine at reflector and can only be seen from dead in front.  Trail and error-and worth buying better quality as in my experience the LEDs go out one by one in cheap bulbs and last only a few months.
FatS
  • nr Chelmsford - ESSEX !
  • sorry about the last avatar :-(
« Reply #14 on: 02 November 2009, 13:46:25 »
I don't think the front side-lights (the 501's) give a fault
warning - i just replaced 1 'cos i SAW it was out but
no message ! (and in handbook the Side-lights aren't
listed)
http://a6.vox.com/6a0110163c0a12860c0123ddb7d276860b-pi
Do those 'tower' ones go into the push-fit hole ??
http://www.autobulbsdirect.co.uk/501-LED-Extreme-Power-1.5W-360-degree.html
http://www.autobulbsdirect.co.uk/501-Long-19-LED-Extreme-Power-2W-360-degree.html
I really don't like the pissy look of the sides when the
Xenons are on  :(
What about those new Halogen 5w ?? are they REALLY
Halogen or just 'Blue' ones ??
http://www.autobulbsdirect.co.uk/501-W5W-Osram-Halogen-Cool-Blue-Sidelights.html
I know the little capped 10w ones in the Mercs/Alfas
ARE Halogen - they're REALLY bright ! !
« Last Edit: 02 November 2009, 14:01:22 by FatSteve »
[ used to have 2.5 MANUAL before . . THAT'S why i've gone for the AUTO :-) ]
