Author Topic: Putting 3.0v6 gearbox into 2.5td omega/ar25-ar35  (Read 1373 times)
stevenpc
« on: 28 February 2010, 20:52:55 »
hi i have a 2.5td with auto box which seems to be stuck in top gear,no fault codes on car so presumming changing is only option, i was thinking of looking for an ar35 box as have heard they are better just wondering will i need a control box aswell or are they compatable to the 2.5td electrics? thanks
« Last Edit: 28 February 2010, 21:19:04 by case015 »
Re: Putting 3.0v6 gearbox into 2.5td omega/ar25-ar35
« Reply #1 on: 28 February 2010, 22:07:54 »
Fully compatible to whats there....just swap the box and keep the original torque convertor
unlucky alf
  • worksop, notts
« Reply #2 on: 28 February 2010, 22:10:52 »
got to change the bellhousing over as well, i would also change the b/housing oil seal while its out :y
stevenpc
« Reply #3 on: 28 February 2010, 22:56:22 »
ok great thanks,will be getting mechanic to fit,i presume changing the bell housing over is straight forward enough..
