Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Help urgent :( , getting so annoyed  (Read 11757 times)
Re: Help urgent :( , getting so annoyed
« Reply #45 on: 28 February 2010, 22:55:46 »
Or Dispack!! :y
For the [size=20]4th[/size] time, it has no dis pack, its coil pack above the plugs.
spray the leads both ends with wd40 to make sure they are not arcing across each other
Definately sure you've connected the leads up correctly and did you use a new DIS?
No leads on 3.2 its coil pack  ;)
Do a pedal trick and post up the codes  :y
How about the leads themselves? They may look new but the could be brittle on the inside.
There are no leads on 3.2 or 2.6
Third time lucky?  ::)  ;D
« Reply #46 on: 28 February 2010, 22:56:31 »
has a coil pack m8  :y
actually has 2 Coil Per Plug modules if you wish to be totally accurate.
Do the pedal trick .. post up all the codes you get.
PM MarkDTM arrange to visit him for a live data reading
Stop guessing
Take car off pistonheads.
Simple  ......  :)
« Last Edit: 28 February 2010, 22:57:29 by entwood »
deejaywardy
  • Grantham
« Reply #47 on: 28 February 2010, 22:57:43 »
got a brand new coil pack on got it day before yesterday
codes
0300
0301
0303
0305
« Reply #48 on: 28 February 2010, 22:59:07 »
codes
0300
0301
0303
0305
Which bank?
« Reply #49 on: 28 February 2010, 23:00:06 »
codes
0300
0301
0303
0305
is that from a generic reader? they often talk 'dangle berries'
« Reply #50 on: 28 February 2010, 23:00:55 »
0301
0303
0305
Earlier posts you did not give these codes? Only missfire on 135 bank?
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
Both coil packs will not fail, and as long as the plugs are clear of oil, if you getting miss-fire across both banks, suggests MAF.
Unplug it and go for a drive
« Reply #51 on: 28 February 2010, 23:00:56 »
also does not explane limp mode
deejaywardy
  • Grantham
« Reply #52 on: 28 February 2010, 23:02:46 »
bank 1,3,5 pack ,,, yeh its off a bosh reader i have ,, ive cleared the erros before and it was fine for about 20 or so miles then started to missfire again ,, now does it offen even after errors are cleared
i would do the pedal trick but car is at my girlfriends house
deejaywardy
  • Grantham
« Reply #53 on: 28 February 2010, 23:04:31 »
yeh only missfire on bank 135
« Reply #54 on: 28 February 2010, 23:09:39 »
bosch are shite, as are snap on.
often give conflicting info, they dont seem to have the complete code list ime
Strongly sugest pedal trick when possible. its free, to confirm accurate code read.
If still 0300 1/3/5 drivers side, check wiring and plug to coil pack (no dis pack or leads) for continuity or damage.
« Last Edit: 01 March 2010, 01:18:39 by chrisgixer »
deejaywardy
  • Grantham
« Reply #55 on: 28 February 2010, 23:13:48 »
Strongly sugest pegal trick when possible. its free, to confirm accurate code read.
checked plug and cleaned it and wires and all seem fine ,, i shall go do the pedal trick 2morrow after work and see what i get and post results ,, i would drive the car to nottingham to see mark but as car is running like it is at the momet its drinking to much fuel and my pockets are a bit empty at the moment  :P
« Reply #56 on: 28 February 2010, 23:24:06 »
ok, also check ucu plug fully home/no corrosion on the pins while your there.
if you have the same codes via pedal trick with new plugs and coil pack and good wiring, then as Entwood says, it needs teach 2 to investigate further, Mark dtm is nearest you, he is far cheaper and better than any garage.
unlucky mark mv6
  • tipton,west mids
« Reply #57 on: 28 February 2010, 23:25:34 »
is it possible the cats are knackered. :-/
« Reply #58 on: 28 February 2010, 23:27:34 »
cant tell anymore without further diagnostic.
too much guess work going on here i'm affraid
webby23
  • Nottingham
  • MV6
« Reply #59 on: 28 February 2010, 23:33:10 »
Whats Grantham to Nottingham?
30 miles.....??
I do it in 45 mins in my 18t truck at 40mph all the way along the A52, so I would say its a 30 min drive in a Mig.....
People are trying to help you buddy but you got to want to help yourself too.....
Pages: 1 2 3 [4] 5  All   Go Up
