Author Topic: Help urgent :( , getting so annoyed  (Read 11826 times)
deejaywardy
  • Grantham
« on: 26 February 2010, 23:47:32 »
ok so my car still has a missfire on cyl 1 , 3 , 5 been told it could be a few things like plugs and coil pack ,, changed the plugs and did the coil pack today and its still missfireing
im so pi**ed off with the car now its costing me so much and its still not right ??
can anyone help please ??
thanks so much Ben
goonv6
Re: Help urgent :( , getting so annoyed
« Reply #1 on: 26 February 2010, 23:50:07 »
Definately sure you've connected the leads up correctly and did you use a new DIS?
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 26 February 2010, 23:50:19 »
did you get a new dis pack? check the plug on the wire make sure that it good and clean. also check the ecu main plug is in tight. and injector relay.
« Last Edit: 26 February 2010, 23:52:35 by Russell_Hill »
deejaywardy
  • Grantham
« Reply #3 on: 26 February 2010, 23:53:14 »
yeh brand new bosh one ,, connecter looked nice and clean to me ,, so lost as what to do as i need the car for work and its just costing me so much to fix but nothing is going rite ,,
would it make any difference if i put the code reader on it and clear the errors becasue when i checked it a while ago it said miss fire etc but never cleared error memory when i fitted new bits ??
« Reply #4 on: 26 February 2010, 23:55:55 »
No leads on 3.2 its coil pack  ;)
Do a pedal trick and post up the codes  :y
rustym95
« Reply #5 on: 26 February 2010, 23:56:20 »
dose the eml light still come on, or is it off?
« Reply #6 on: 26 February 2010, 23:56:40 »
out of interest, do you have K&N panel or cone filter fitted?
« Reply #7 on: 26 February 2010, 23:57:19 »
How about the leads themselves? They may look new but the could be brittle on the inside.
There are no leads on 3.2 or 2.6
« Last Edit: 27 February 2010, 00:04:30 by tunnie »
deejaywardy
  • Grantham
« Reply #8 on: 27 February 2010, 00:03:13 »
ill run the code reader 2mora and let you know all the codes ,, no its running standard air box and the eml is off , never came on just got the missfire
« Last Edit: 27 February 2010, 00:04:02 by deejaywardy »
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #9 on: 27 February 2010, 00:48:01 »
Sorry if I'm asking the obvious, but you don't have any water getting in there from the scuttle?? Took me ages to find it on mine (got there in the end thanks to Tunnie  :y) although mine was on the other bank.
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
« Reply #10 on: 27 February 2010, 06:14:45 »
thanks so much Ben
where are you getting the missfire info? from the pedal trick? or code reader? exactly what codes are you getting?
 missfire codes start p030* iirc
« Reply #11 on: 27 February 2010, 06:30:23 »
you can read the codes yourself here,
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
although you do need a code reader to clear them.
dave10
  • sunderland
« Reply #12 on: 27 February 2010, 08:50:36 »
spray the leads both ends with wd40 to make sure they are not arcing across each other
RobseyMV6
  • west sussex
« Reply #13 on: 27 February 2010, 09:24:58 »
Mate, there are no leads on 3.2
« Reply #14 on: 27 February 2010, 09:42:40 »
Third time lucky?  ::)  ;D
