Author Topic: paper clip test  (Read 1825 times)
gateshead
paper clip test
« on: 28 February 2010, 19:42:49 »
hi i have a omega 2.5td i am trying to do a paper clip test but a bit confused (the system flashes a 1-2 (12) 3 times to indicate start of sequence) so does it mean 1-1-2-1-2-3 blinks 12 times. so how many blinks should ther be before i need to start counting the blinks for codes
Bumbazor
  • Worksop
Re: paper clip test
« Reply #1 on: 28 February 2010, 19:52:33 »
You're right saying you see 12 three times.
You should see:
blink
blink blink
blink
blink blink
blink
blink blink
...and then the codes if any. If you see 12 again it means there are no fault codes stored. Be careful though, the absence of flashed codes doesn't necessarily mean the absence of faults.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: paper clip test
« Reply #2 on: 28 February 2010, 19:54:29 »
in groups of 3. 1flash then 2 flash etc, then if only dose number 12, and nothing els it may be somthing els another ecu.
gateshead
Re: paper clip test
« Reply #3 on: 28 February 2010, 20:01:22 »
You should see:
blink
blink blink
blink
blink blink
blink
blink blink
hi so ware does the 12 come into it there is only 9 blinks there appoliges for bieng dumb
Bumbazor
  • Worksop
Re: paper clip test
« Reply #4 on: 28 February 2010, 20:09:21 »
blink = 1
blink blink = 2  ....
... and so on
gateshead
Re: paper clip test
« Reply #5 on: 28 February 2010, 20:15:14 »
thanks guys sused it just was not counting the codes three times when the codes started cheers
blakjak
  • watford
Re: paper clip test
« Reply #6 on: 28 February 2010, 20:32:28 »
Hi I also was trying the paper clip test and got confused on the blinks so after after the 3 blinks has passed is it then you count count how many blinks?
Re: paper clip test
« Reply #7 on: 28 February 2010, 20:37:19 »
Have a look here http://www.omegaowners.com/forum/YaBB.pl?num=1259003779- links to guides to paper clip tests
gateshead
Re: paper clip test
« Reply #8 on: 28 February 2010, 20:55:01 »
yes so you count
1blink
1blink 1blink
1blink
1blink 1blink
1blink
1blink 1blink
1blink
1blink 1blink
so there is your 12 count then your codes will count if any so say code 35 comes up t will blink
1blink 1blink 1blink
1blink 1blink 1blink 1blink 1blink
then it will repeat this twice more
then if there is no more codes it will revert back to the start seqense
blakjak
  • watford
Re: paper clip test
« Reply #9 on: 28 February 2010, 21:17:12 »
Ok gateshead thanks that's very helpful tomorrow I'll try the test and see what numbers I'll get in relation to the blinks  :y
hoofing it
Re: paper clip test
« Reply #10 on: 28 February 2010, 21:20:45 »
yes so you count
1blink
1blink 1blink
1blink
1blink 1blink
1blink
1blink 1blink
1blink
1blink 1blink
so what codes have you got showing up  :y
blakjak
  • watford
Re: paper clip test
« Reply #11 on: 02 March 2010, 18:21:57 »
Hi all i've just done the paper clip test and can someone please tell me what 17 is which stand for knock signal circuit 2 and 93 which stands for hall sensor voltage low what are they.
