Author Topic: rear blind  (Read 1173 times)
a2reed
  • Battersea London
rear blind
« on: 28 February 2010, 20:21:01 »
Has stopped working.... is there  arepair kit available anywhere .... I am guessing a worm gear or somesuch wears out or is it the motor not sure... guess I am asking 2 questions
1... What is the common reason for the blind to stop working
2... Is there a repair kit (cheap as I aam broke)
any help appreciated
Bumbazor
  • Worksop
Re: rear blind
« Reply #1 on: 28 February 2010, 20:30:44 »
First check the fuse, then:
1. Not sure if there is a common reason but we can try to narrow it down; do you hear any clicks, or movement of any kind form the blind when you try to raise it?
2. When you know what is wrong you can then go on to find the replacement. It could be as simple as a gear, like you say, or it might be like what happened on mine which was a blown track on the PCB.
You might have to disassemble the blind to find the faulty part.
a2reed
  • Battersea London
Re: rear blind
« Reply #2 on: 01 March 2010, 11:13:00 »
Yes when I activate the button a geta  clicking sound
a2reed
  • Battersea London
Re: rear blind
« Reply #3 on: 04 March 2010, 13:46:07 »
Is there acommon fault with this blind?
less
  • Hemel Hempstead
    • 2.6 auto saloon
Re: rear blind
« Reply #4 on: 04 March 2010, 21:17:50 »
Yes, several people on here have had this problem. Usually it is caused by a bad connection on the motor. I think mine was a poor earth connection. Cleaned and is still working a couple of years later.
