Author Topic: Coolant temprature 2.5 diesel  (Read 1255 times)
abtfinman
  • Merthyr Tydfil South Wales
« on: 02 March 2010, 19:57:56 »
Hi All
Sorry if this has been covered before but I seem to have lost the search facility.
Firstly may I thank everyone who has posted "how to" guides, they really are invaluable.
Using the advice here I have cured my overheating 2.5 diesel by changing the thermostat and water pump. The plastic impeller really was in a bad way.
The car is running well but I am a little concerned about the coolant temprature showing on the gauge.
It reads just over or just under the 95 mark. Is this where it should be or have I stilll got a problem.
Thanks in anticipation
Alyn
MickAP
  • South Derbyshire
Re: Coolant temprature 2.5 diesel
« Reply #1 on: 02 March 2010, 20:12:15 »
Mine sits at around 85, has done since stat was changed last year :y
Mick
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 02 March 2010, 20:17:49 »
It should run normally at around the 92 mark on the gauge.
Approx mid point on the scale.
« Reply #3 on: 02 March 2010, 20:46:35 »
Please see FAQ section for running temps.  It is not possible to say it should run at x degrees, as it varies depending on age ;)
abtfinman
« Reply #4 on: 05 March 2010, 08:10:14 »
Thank you all.
The photograph in the FAQ section shows a temprature gauge in exactly the position mine shows when running.
When I removed the water pump the impeller was virtually in bits. Did not have enough pieces to say I had the whole lot.
Does the plastic wear away or indeeed melt over the years?
Alyn
« Reply #5 on: 05 March 2010, 08:20:14 »
Thank you all.
Alyn
No, the broken bits of imellor tend to find a place in there to live out their life. Often possible to get some bits out by reverse flushing it with pump and stat out.
abtfinman
« Reply #6 on: 05 March 2010, 08:35:10 »
No, the broken bits of imellor tend to find a place in there to live out their life. Often possible to get some bits out by reverse flushing it with pump and stat out.[/quote]
Thanks Big Boy. Guess i will just have to live with it
Alyn
« Reply #7 on: 05 March 2010, 14:05:57 »
Alyn[/quote]
Oh aye!! Anything going on the rest of us should know about ? :D ;D ;D ;D ;)
abtfinman
« Reply #8 on: 05 March 2010, 15:19:45 »
Oops is that whats known as a freudian slip (No I just cannot type)  :)
