Author Topic: Help!! Water dripping from behind crank pully  (Read 1056 times)
Ianb
  • Cheltenham, GLOUCESTERSHIRE
« on: 05 March 2010, 14:28:19 »
Completed oil cooler change and flushed out all the gunge. Reassembled with new thermostat and all appeared well. Then noticed coolant dripping from behind crank pully. Thought it could be from the thermostat link pipe.  Checked all around and could not see anything so decided to take everything apart again in case it was the oil cooler plate not sealed properly.
On checking, all dry as a bone, but the water keeps dripping. It drips dead centre behind the crank pully, and at a reasonable rate.
Any ideas from thos that know??  Hope it isn't the head gasket.
Re: Help!! Water dripping from behind crank pully
« Reply #1 on: 05 March 2010, 14:30:30 »
Could it be water pump leaking and running down :-/ :-/
Ianb
« Reply #2 on: 05 March 2010, 14:43:36 »
I thought about that, but the water pump is over to the right a bit, isn't it? The water is dead centre.  However, as it is coming out quite quickly, it's maybe water pump than head gasket, what do you think?
Thanks for the reply.
« Reply #3 on: 05 March 2010, 14:52:01 »
if pump leaks, it does tend to run behind crank pulley
Ianb
« Reply #4 on: 05 March 2010, 15:20:32 »
OK, thanks.  Is there a maintenance guide for replacing the water pump available?
Thanks and regards
« Reply #5 on: 05 March 2010, 15:25:06 »
Get V6 cambelt DVD (OOF Shop) - it shows the water pump being swapped on there  :y
[edit]see here £3 only http://shop.omegaowners.com/index.php?main_page=index&cPath=3&zenid=3t80sm4dnvk83iiqrqd82qdcb1[/edit]
« Last Edit: 05 March 2010, 15:26:31 by dbug »
