Author Topic: major problem peeps  (Read 3971 times)
matt leadbetter
  • leicester
    • 01, 2.2 cdx estate
major problem peeps
« on: 02 March 2010, 14:56:25 »
my v6 is acting very odd once warmed up it struggles to accelerate and jerks a lot have change egr valve, plugs, leads and about to change fuel filter and about to check to multiram as suggested but i don't know how to check the multiram have reved car but no movement does it have to be under load to see any movement?
mtbskills
  • Pontypool
Re: major problem peeps
« Reply #1 on: 02 March 2010, 15:30:00 »
I had to rev mine REALLY hard to get the multirams to move. (98 v6)
Give it a few blips then full throttle and trust in the rev limiter !
About to change my fuel filter too, be interesting to see what difference it makes
« Reply #2 on: 02 March 2010, 15:52:18 »
Whilst malfunctioning multirams will result in a noticeable loss of power, your issues sound worse than that, so I would look elsewhere.
Does the car run perfectly normally until warm? How far will it drive before you get problems?
Is the car getting up to normal running temperature ok?
Does the car accelerate OK under full throttle but run lumpy under light throttle?
Also - it's best not to throw new parts at a car with a problem. Find out what is causing it first. A fuel filter, for example, will affect the running whether the engine is hot or cold, so I doubt that is the issue.
I would be checking the coolant temperature sensor first, followed by the Lambda sensors and for any air leaks into the induction and exhaust systems.
Firstly, because the ECU could be fooled into thinking the engine is cold when it's not, hence running an incorrect mixture.
Secondly, when the engine is warmed up, the lambda sensors start to control the mixture, so if anything is fooling them it will affect warm running.
mtbskills
  • Pontypool
« Reply #3 on: 02 March 2010, 15:56:00 »
would there be any codes for the lamda sensors ?
« Reply #4 on: 02 March 2010, 15:58:32 »
it depends. You might get a fuel trim code if they have taken the fuel far out. So, worth doing a paperclip test and reporting any codes.  :y
matt leadbetter
  • leicester
« Reply #5 on: 02 March 2010, 20:23:17 »
Hi Kevin,
The car runs fine until warm, it's getting up to running temperature ok and it does run lumpy under light throttle. The distance it drives before the problems starts depends on the day. On a warm day it'll start quicker than on a cold day. It seems to start when the automatic choke stops.
Can you tell me how to find the coolant temperature sensors, lambda sensors and induction and exhaust systems?
Matt
« Reply #6 on: 02 March 2010, 22:40:01 »
The first thing to do is check for fault codes, I would say.
Have a look here:
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
You need to do a paperclip test on your car. :y
matt leadbetter
  • leicester
« Reply #7 on: 02 March 2010, 22:42:50 »
does the paper clip test show any different faults that a diagnostic machine would show because have used a machine and no fault codes
« Reply #8 on: 02 March 2010, 23:34:10 »
No, but worth spending 5 minutes checking anyway.
Are there any signs of a blow from the exhaust manifolds or downpipes?
It might be worth considering getting it to one of us who have a Tech 2. See if there are any clues in the live data (e.g. we can check that the coolant temperature is being reported correctly).
Ignition system problems will often result in no fault code. Now, I know you have changed some items there but perhaps a coil pack?
I think it would be helpful for someone to have a look at the live data.
matt leadbetter
  • leicester
« Reply #9 on: 03 March 2010, 12:06:31 »
have done paper clip test and put on a diagnostic machine no codes so whats my next step
mtbskills
  • Pontypool
« Reply #10 on: 03 March 2010, 15:13:39 »
have you changed the fuel filter yet ?
I realise it should make a difference with engine hot and cold, but on past experience
(not omega's granted ), any fuel problems are much more obvious when engine warm and not running a rich mixture on "choke"
bluepoint
  • Warrington
« Reply #11 on: 03 March 2010, 15:20:56 »
Sound like the DIS pack to me.
Andyb
  • Lincoln
« Reply #12 on: 03 March 2010, 16:24:26 »
i concur i had a vectra that did the same many yrs ago was fine untill hot then started playing up
on inspection the dis pack had a slight crack that would open up when hot causing a short
« Reply #13 on: 03 March 2010, 17:23:03 »
Could well be DIS pack based on lack of codes, I agree. Worth getting it out for a visible check on condition, pain in the @rse though it is.
matt leadbetter
  • leicester
« Reply #14 on: 03 March 2010, 20:09:38 »
Thanks peeps. I will try, anyone know how to get to the dis pack?
