Author Topic: oil smell in car  (Read 1884 times)
andykaz
  • Harecroft, Nr Bradford
  • i loved the 80's... ohh and cars..!
oil smell in car
« on: 07 March 2010, 16:52:33 »
hi guys
just a quick one.
getting a strong oil burning smell coming into the cabin when the vent fans are on. i've only had the car a week and am working through a few issues. i'm gonna do a full oil flush and change but suspect the smell is due to poor crank case breathing. does that sound right? if so is there a kit or is it a case of replacing a few hoses? also i've seen a crank case filter online that seems to do away with all the plumbing. anyone know if they work?
cheers guys
andy
amba
  • Medway towns
    • German V6
Re: oil smell in car
« Reply #1 on: 07 March 2010, 17:01:21 »
Sounds like you have a leak from one of the plastic cam covers..probably due to poor servicing in a previous life.
Have a good check for leaks where the plastic covers meet the heads..comman problem and very well documented in maintenance guide..only replace with genuine GM gaskets and when done give the breather system a thorough clean..that should be the end of the oil smell....then enjoy your new car .
andykaz
« Reply #2 on: 07 March 2010, 17:05:09 »
nice one fella
i wouldn't have thought of checking the covers but it makes loads of sense.!
cheers mate.
andy.
amba
  • Medway towns
    • German V6
« Reply #3 on: 07 March 2010, 17:11:33 »
Normal problem is caused by poor servicing of the oil.This then causes the breather system to get partially blocked and then the weakest point is the cam cover gaskets which then drip oil onto the hot exhaust manifolds and smell like "bacon frying" and you get the occassional puff of smoke from the bonnet edges.
Think most of us have been there at some point in our ownership...trick is to do it/or get it done properly using only genuine gaskets and sealant..have a read through the maintenance guide..it will then make the problem and its cure very clear.
andykaz
« Reply #4 on: 07 March 2010, 17:32:15 »
thanks again mate
just looked at a guide in the how to section and it seems easy enough.
will do it this week.
cheers
andy
Bumbazor
  • Worksop
« Reply #5 on: 07 March 2010, 18:10:31 »
It is one of the easier jobs but as I am sure you will have read in the guide, the most important things are that genuine GM gaskets are used, bolts torqued to 8Nm, BLACK sealant used, and breather system cleaned properly.
Bent valve
« Reply #6 on: 07 March 2010, 18:28:08 »
You must eat some crap bacon if it smells like engine oil on a hot manifold ;D
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
« Reply #7 on: 07 March 2010, 18:31:05 »
Try unsmoked! 8-)
