Author Topic: code 135  (Read 1035 times)
des.allen
  • Preston lancs
  • 2000 2.5 v6 elite nearly LPG
code 135
« on: 07 March 2010, 17:13:13 »
Hi, just done paperclip test and it threw up code 135   Telltale (Checklight) Voltage Low. Any ideas   Thanks Des :)
Re: code 135
« Reply #1 on: 07 March 2010, 17:43:54 »
If that`s all you got, ignore it
des.allen
  • Preston lancs
Re: code 135
« Reply #2 on: 07 March 2010, 19:16:55 »
Cheers Rob but what is it?
Bumbazor
  • Worksop
Re: code 135
« Reply #3 on: 07 March 2010, 21:10:36 »
It's the light you counted the flashes of.
Re: code 135
« Reply #4 on: 07 March 2010, 21:24:03 »
ignore - could be you've had ign on with dash out, or battery was low.  just ignore
des.allen
  • Preston lancs
Re: code 135
« Reply #5 on: 08 March 2010, 20:12:32 »
