Author Topic: Auto Gearbox Problems  (Read 3609 times)
anth.payne
  • Cornhill, Northumberland
« on: 05 March 2010, 17:55:34 »
Hi Guys - newbie here so please give me some slack  ;)
Today i got an Omega - taking a bit of a chance on it, as the gears arnt running correctly.
The auto wont appear to go beyond 3rd, and wont go beyond 60.  It also sometimes take 2 attempts to get it into reverse...
The previous owner said it ran perfectly until he got stuck in snow, and tried getting out by rocking the car using reverse/first.
I see from the manual there is an ice mode - which I presume would have this effect on the drive? Lower torque/speed...
If this is the case, how do i get it off?
Thanks in advance
mrcnc53
  • Portsmouth
Re: Auto Gearbox Problems
« Reply #1 on: 05 March 2010, 18:17:56 »
The snow/ice button is on the left hand side of the
gear lever. With it on the car will start off in third.
Budgie
  • Lincolnshire
« Reply #2 on: 05 March 2010, 18:18:36 »
Thanks in advance
Hi,
If I'm reading your post correctly then you should be able to switch off 'Snow Mode' by pressing the button to the left of the gear shift - it has a snowflake symbol on it. However - not sure what model you have but hope this helps.
Good luck!
I spend far too much money on my Omega
anth.payne
« Reply #3 on: 05 March 2010, 18:48:00 »
Sorry  - it's a 2.2 16v
Not sure if it could be the snow mode then... as it starts in 1st but won't go past 3rd, and wont exceed 60mph
« Reply #4 on: 05 March 2010, 18:56:24 »
snow mode automatically dis-engages at around 40mph iic, does the engine rev over 4k rpm?
Worth updating your profile with your location, we may have members with tech2 near you to read the codes  :y
« Last Edit: 05 March 2010, 18:56:44 by tunnie »
ians
  • Reading
« Reply #5 on: 05 March 2010, 19:00:03 »
the usual first step is to top up the ATF fluid
anth.payne
« Reply #6 on: 05 March 2010, 20:06:05 »
I have updated my location.  I will check the ATF in the morning.
Thanks
« Reply #7 on: 05 March 2010, 20:51:53 »
snow mode automatically dis-engages at around 40mph iic, [size=14]does the engine rev over 4k rpm?[/size]
Martin_1962
« Reply #8 on: 05 March 2010, 20:59:47 »
I reckon selector switch is worth checking, but TBH sounds like it could be a damaged box - the rocking may have done something bad
anth.payne
« Reply #9 on: 06 March 2010, 15:29:57 »
Well today I popped into town, and went to the vauxhall garage.  They have advised me the gearbox sump gaskets are discontinued... hmmm
Well i bought some ATF fluid (not from vauxhall) and drained out what i could from the level plug by jacking it up at pass. side, then following the instructions on here...
Still appears to be no improvement.
Thought i would explain in a bit more detail what is happening with the gear stick lights:
P = All lights on
R = R light is on
N = All lights on
D = 3 light comes on then all lights go on after a few seconds
3 = 3 light is on
2 = All lights on
1 = All lights on
I'm wondering whether this is a problem with the gearbox ECU?  Where will i find this?  And can they be replaced easily?
Thanks
anth.payne
« Reply #10 on: 06 March 2010, 15:30:40 »
Yes it revs over 4k
SJKOO01
« Reply #11 on: 06 March 2010, 16:53:46 »
P = All lights on
R = R light is on
N = All lights on
3 = 3 light is on
2 = All lights on
1 = All lights on
Thanks
Go to this site, may help you ?.
www.jpat.co.uk
DillonV6
« Reply #12 on: 06 March 2010, 17:53:19 »
Mine was the same it was the range sensor cost £500 to replace take it to a specialist auto box repairer and have a diagnostic test done cost about £60 its well worth it though as you'll know exactly whats wrong i used Midland auto transmissions in Kettering Northants
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #13 on: 06 March 2010, 20:40:54 »
If it's gonna cost mega bucks to fix it, you might want to consider converting it to manual!
anth.payne
« Reply #14 on: 06 March 2010, 22:35:33 »
is it dificult to convert to a manual?
TBH - i quite like the auto box, and the unusal thing is, it isn't malfunctioning as such as the gears stil change smoothly etc...
I have an auto specialist local (which out local vauxhall dealer sub contract to - as they dont service auto's)... may be worth a visit
