Author Topic: borescope recommendations  (Read 1996 times)
« on: 08 March 2010, 12:13:00 »
been after one for ages, now seems like a good time to get one, not cheap from what i've seen, needs to fit through a spark plug hole, and be able to view the valves although cost may prohibit this function as i guess it will have to have direction control.
Looked into hiring, could almost buy one for the cost of a weeks rent.
Wouldnt normally post this here but TB s car needs sorting.
Re: borescope recommendations
« Reply #1 on: 08 March 2010, 12:18:51 »
We have a Plan C now, thought I mentioned it in pub yesterday? Details still to be worked out.
« Reply #2 on: 08 March 2010, 12:29:13 »
Buy a tractor?  ;D
« Reply #3 on: 08 March 2010, 12:34:57 »
Buy a tractor?  ;D
I miss my tractor, even more so at times like this  :'(
rather Kawasaki tomorrow. Brrrrr!  I'm a fair weather biker, and proud of it!
« Reply #4 on: 08 March 2010, 12:35:45 »
Buy a tractor?  ;D
You'd be wanting those 'gay' heated grips tomorrow morning
« Last Edit: 08 March 2010, 12:36:08 by tunnie »
« Reply #5 on: 08 March 2010, 12:39:21 »
Buy a tractor?  ;D
you will be freezing within your deepest cells :-/
hoping young nurses will behave nicely at the hospital :y
« Last Edit: 08 March 2010, 12:41:02 by cem_devecioglu »
« Reply #6 on: 08 March 2010, 13:03:24 »
MMMM   decidedly NOT cheap ...  :(
http://www.pvrdirect.co.uk/productinfo.aspx?catref=VS8191
Even hiring one looks expensive ... although you mind find someone local I suppose ..
http://www.inlec.com/inspection-c10?gclid=CIWmvMKaqaACFUIA4wod5mlGaQ#:c79
« Reply #7 on: 08 March 2010, 13:12:35 »
I wonder if this would go down a plug hole  :-/ it doesn't seem to give the probe diameter
http://www.maplin.co.uk/module.aspx?moduleno=259804
« Reply #8 on: 08 March 2010, 13:19:00 »
 Technical Specification
Technical Specifications:
Camera Specifications:
Image Sensor 1/3" CMOS
Effective Pixels 704x576
View Angle 50 Degree
Transmission Frequency 2486MHz
Power Supply 4 x AA
Dimensions:    186mm x 145mm x 41mm
Weight:    530g
Monitor Specifications:
LCD Screen Type 2.36" TFT-LCD
Effective Pixels 480 X 240
Video System PAL / NTSC
Power Supply 8V-36V
Consumption Current 450mA
Dimensions:    100mm x 70mm x 30mm
Weight:    140g
and in the "comments" section....
10. It would be nice to see on the Specifications that the Optic Tube is 9.5mm approx. diameter throughout most of its length, but 16.36mm approx. diameter at the business end. i.e. not quite small enough to enter a 14mm spark plug hole, and also show the minimum focussing distance.
« Reply #9 on: 08 March 2010, 13:22:10 »
Power Supply 4 x AA
Weight:    530g
Power Supply 8V-36V
Weight:    140g
I read the tech spec but not the comments  ;) :y
« Reply #10 on: 08 March 2010, 13:28:19 »
We use something similar to that on the loco and to inspect steam tubes and presure vessels.
It works very well but, the end would be to big to fit through a spark plug hole
« Reply #11 on: 08 March 2010, 17:14:43 »
right, did some asking around, found a serious piece of kit that has all the bells and whistles i'm told. Exchangable directable attachments...and i can borrow it... :y
hotel21
  • The Kingdom of Fife
« Reply #12 on: 08 March 2010, 19:17:39 »
Sounds like a plan.....   ;)
Just so long as some unsuspecting bugger* does not get an uncleaned one inserted at some stage....
* use of sweary word specifically apt, I think....
[Those carbon crystals really itch (so I'm told...)   ;D  ]
« Last Edit: 08 March 2010, 19:17:54 by hotel21 »
Steveplumb
  • Radstock, Near Bath
« Reply #13 on: 08 March 2010, 20:06:42 »
Recently bought this camera type as compared to fibre optic . http://cgi.ebay.co.uk/CAVITY-INSULATION-INSPECTION-CAMERA-TFT-SEESNAKE-10mm_W0QQitemZ230384903199QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item35a402a41f   Very pleased with it , can usually get them for £80 from him !!
« Reply #14 on: 08 March 2010, 21:30:36 »
seems to be the choice, fibre optic, or camera with screen. Only fibre optic seem to be able to turn around in the bore and look back up at the valves though afaict, and guess which ones are most expensive...
