Author Topic: 2.5 TD Lift Pump  (Read 1029 times)
gateshead
2.5 TD Lift Pump
« on: 08 March 2010, 20:54:13 »
hi guys i tried the lift pump cleaning to day from the guide. there was no real slime or build up of dirt. but my car is still stalling when coming up to a junction. is there any other things i can try and look at next to try and sort this problem. cheers kevin
hoofing it
Re: 2.5 TD Lift Pump
« Reply #1 on: 08 March 2010, 21:09:23 »
it could be a broken pipe in the fuel tank ,filter drawing air lift pump knackerd i'd paper clip it.
does it restart straight away there could be a number off faults
« Last Edit: 08 March 2010, 21:10:57 by hoof »
gateshead
« Reply #2 on: 08 March 2010, 21:28:26 »
the pipe in the tank looks ok. the car does not start strait away either. there are no codes from the paper clip test. any suggestions would be helpfull. i am going to do a service somtime this week ie air filter, glow plugs, fuel filter, oil filter and oil do you think any of these will help or could it be the pump its self thats knackerd
PC Techy
  • Bath
« Reply #3 on: 08 March 2010, 22:35:40 »
Would i be right in saying the lift pump only runs on cold starts, and not during normal running. I know my old 325tds ran that way and so does the current tractor,it cuts out just after the glow plug light goes out.  I know on the bmw's the lift pumps can break at the top where the pipes attach, so they suck air if the fuel level is to low. Does it start if tank level over half way (roughly top of pump) ?
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
Ddraigcymro
  • South Wales
  • Hate the game not the player!
« Reply #4 on: 09 March 2010, 00:43:33 »
A few people have tried explaining to me about injector failing and the symptoms involved, but my cure for stalling at junctions is to add more fuel to the tank, I no longer use the fuel gage reading unless flushed and want full/ 3/4 tank and use the stalling as my fuel top up time. I have assumed(and yes that spells `ass u me d`) all sorts else wrong with the motor, I have also cleaned the lift pump ext it made no difference for me.
I don't suffer from insanity, I enjoy every minute of it.
