Author Topic: Multi Ram & T Cs??  (Read 1440 times)
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Multi Ram & T Cs??
« on: 09 March 2010, 00:10:13 »
Today I started my cambelt and thermostat change,and came across an obvious fault that has possibly been there since I got Miggy.When I came to remove the multi ram unit there's what I think is an ECU current operated diverter valve, to control the vacuum operated multi ram throttle control.The query I have is as the vacuum supply pipe was disconnected (the rubber connector sleeve was'nt present)So no vacuum supply.This means I think that the ECU has been unable to operate the multi ram system. So my big question is. Why no TCs?? Or is this a fault not covered by TCs. There is also possible faults caused by low vacuum in the rest of the vacuum system. I hope I've managed to explain it OK.Anyhow looks as if I can look forward to some improved performance levels.Just need a rubber connector sleeve or elbow. :y :y :y
Re: Multi Ram & T Cs??
« Reply #1 on: 09 March 2010, 08:21:58 »
Today I started my cambelt and thermostat change,and came across an obvious fault that has possibly been there since I got Miggy.When I came to remove the multi ram unit there's what I think is an ECU current operated diverter valve, to control the vacuum operated multi ram throttle control.The query I have is as the vacuum supply pipe was disconnected (the rubber connector sleeve wasn't present)So no vacuum supply.This means I think that the ECU has been unable to operate the multi ram system. So my big question is. Why no TCs?? Or is this a fault not covered by TCs. There is also possible faults caused by low vacuum in the rest of the vacuum system. I hope I've managed to explain it OK.Anyhow looks as if I can look forward to some improved performance levels.Just need a rubber connector sleeve or elbow. :y :y :y
The lack of TC's is an easy one to answer.
The ECU is an electrical device and it can sense the presence of the electrical part of the solenoid which I guess is all ok.
To sense the lack of vac due to a split pipe would require further pressure sensors, wires, connectors etc which adds cost and unnecessary complexity.
Cliffo B
« Reply #2 on: 09 March 2010, 10:43:42 »
Thank you Mark, I did wonder if that would be the answer,I'll wait and see how it goes when Miggy's up and running again :y :y :y
